Hello, I now the ADUC 814 is very old, but if there are still people here to help me with SPI communication.
I will try to explain as much as possible with all details.
Firstly my block schematic :https://user-images.githubusercontent.com/40359579/67375267-a9830380-f582-11e9-91c9-7113fc9ee1f4.png
Master : UM232H (python code) https://www.ftdichip.com/Support/Documents/DataSheets/Modules/DS_UM232H.pdf
Slave : Aduc 814 (c code, using uVision) https://www.analog.com/media/en/technical-documentation/data-sheets/ADUC814.pdf
My python code is using pyftdi https://eblot.github.io/pyftdi/api/spi.html
This is my python code :
import sys sys.path.append("C:/Users/aguillem/AppData/Local/Continuum/anaconda3/Lib/site-packages") from pyftdi.spi import SpiController spi = SpiController(cs_count=1) spi.configure('ftdi://ftdi:232h:FT337Y88/1') slave = spi.get_port(cs=0, freq=1000000, mode=3) # 0 = half duplex // 3 = full duplex write_buf = b'\x00\x03\x04' read_buf = slave.exchange(write_buf, duplex=True).tobytes() print("write buf ¦{}¦ \nread buf ¦{}¦".format(write_buf, read_buf))
This is my c code (I had to change to .txt to upload it) :
#include <ADUC814.H> #include <stdio.h> #include <math.h> #include <string.h> #include <GLOBAL.H> #include <FUNCTION.H> /* SPI port interrupt service routine */ void spi_int () interrupt 7{ recieved_byte = SPIDAT; // clear by reading sent_byte = recieved_byte + 1; SPIDAT = sent_byte; } unsigned char enable_interrupts() { EA = 1; // Enable General interrupts IEIP2 = 0x11; // Enable SPI interrupt with high priority return 0; } unsigned char init() { /* Select core clock */ PLLCON = 0x04; //16.77216 MHz (0x01 = 8.388608 MHz | 0x03 = 2.0971 MHz) /* Configure SPI */ SPICON = 0x28; // CPHA=0, CPOL=1, Slave CFG814 = 0x01; // Enable SPI interface return 0; } //----------------------------------------------------------------------------- //MAIN C function //----------------------------------------------------------------------------- void main (void) { unsigned char chan_2_convert; // Initialize init(); enable_interrupts(); while (1) { } }
And this is what I have on the oscilloscope:
And what I have on my python console :
write buf ¦b'\x00\x03\x04'¦read buf ¦b'\x01\x00\x00'¦
Process returned 0 (0x0) execution time : 0.307 sPress any key to continue . . .
So my problem is that I should have, or at least want to have is my code is wrong, the MOSI incremented by 1 on the MISO signal, and here there is only the first byte which is incremented.
And another things which is wrong is I have to run the python program 2 times before seeing the incremented signal, the first time he return all 0x00, and the second it return 0x00 +1
Clock form the python (Master) 2MHz, clock for the slave (C code) set to 1MHz, I tried to change both Slave and Master clock and either Master 2 or 4 time more or less than the slave but alwas the same behavior.Someone knows what to do ?
Sorry for my late replay
Broeker said:Yet according to your earlier message, and the comments in the code, you chose about 1 MHz. So which is it, actually?
Yes sorry it's 1MHz.
Broeker said:It's not quite that simple. SPI slaves in microcontrollers do have limitations on how high an SPI clock frequency they can handle, in relation to their core clock.
Okay but if it can run up to 16MHz, it's probably fine to run it at 1MHz then.
Broeker said:For such an antique, running at a measly 1 MHz, all those steps will quite certainly take longer to perform than the entire rest of the inbound telegram takes to fly right past it. In other words: the earliest you can realistically expect the reply to the first byte of that 3-byte telegram to go onto the line is as the first byte of the next telegram. Which, I think, is exactly what happens.
I haven't understood everything about the reason why this happen and the solution you propose.
That's mean 1MHz isn't is enough quick ?
I Just tried with 10MHz from the CLK and the slave to 16MHz, and I got the same, tried with 2 bytes, the 1st is incremented well but after the second byte remain 0.
And let the slave to 16MHz while putting the master CLK at 250KHz and no incrementation at all the difference where too big.
And after put both clock at 250KHz and it work again, so the second byte isn't usable because of the clock speed.
Spartan said:That's mean 1MHz isn't is enough quick ?
It means a core clock of 1 MHz is way too slow for the '51 CPU core in there to keep up with your SPI transactions. Note that is the ancient, original 12-block '51 core. I.e. it takes at least 12 core clock cycles to execute a single machine instruction.
That means at 1 MHz core clock, there'll be only about 2 machine instructions possible in the time of that entire 24-bit, 1 MBaud SPI telegram. The simulator clocks your interrupt handler at 137 microseconds ... that's about 4 entire 24-bit telegrams.
Spartan said:the second byte isn't usable because of the clock speed.
No. It's unusable because of the mismatch between your expectations and the possibilities of the built-in CPU core. Even at the full 16 MHz core clock, this core could not realistically finish with the interrupt handler betwen two bytes of that telegram. At that speed, it's essentially a lottery which of the many bytes you send will happen to be lying in the SPIDAT when you read it, and also when the reply you write into SPIDAT may end up on the line.
Why are you even sending 24-bit telegrams here? The ADUC cannot possibly keep up with those.
