Hello!
In keil map file, I don't know all the title name's meaning. For example, what does the 'Idx' mean in Memory Map of the image section of map file?
What's the letter "E" in this section before Section Name?
Thanks!
Got a shelf full of manuals from the SDT / ADS days. The ARMLINK manual wasn't much help
http://infocenter.arm.com/help/topic/com.arm.doc.dui0804b/ARMCT_armlink_reference_guide_v6_01_DUI0804B_en.pdf
I try to pull information out of the ELF/AXF file, tends to be more strongly defined, for compatibility reasons. I think the .MAP file is considered a more transitory format, subject to change to suit the linker and architecture it is linking for. I build scripts to process them, and fix them when they break.
Thank you, you are so kind.
