We are using LPC4088 with DP83848 PHY for Ethernet communication.
If we does not supply power to PHY or it is not present on PCB & if call the netInitialize(); function then program crash.
After crash it does not go to any exception handler.
It should return Ethernet driver error or initialize fail error.
Amogh said:netInitialize
You mean this:
https://www.keil.com/pack/doc/mw/Network/html/group__net_sys___func.html#ga0c68e74df79a37750413f72518f63f73
Amogh said:It should return Ethernet driver error or initialize fail error
Should it?
Maybe it assumes that the hardware is present & powered-up ?
