Stepping through code interrupted
Hi everybody,
I'm currently evaluating Arm Development Studio as a replacement for uVision from Keil MDK.
I'm using the most recent version with an STM32H7, currently debugging the M7 core with an STLINK V2 - altough the problem persists with a J-LINK.
Currently, I'm struggling to properly step through code. As I have several periodic interrupts, I'm always ending up in an interrupt.
While this makes sense - interrupts occur at several kHz - this behavior is very different from how debugging worked in uVision where, while stepping through code, interrupts seem to be disabled.
I had a look through the commands listed here: https://developer.arm.com/documentation/101471/2000/Arm-Debugger-commands?lang=en but could not identify a command to disable interrupts while stepping through the code.
Is there any way/option to replicate how uVision stepped through code?
Thanks in advance, any help is highly appreciated!
There are no posts to show. This could be because there are no posts in this forum or due to a filter.
