I compiled my project with a toolchain out of buildroot and everything works fine expect that i get a warning in the Commands-Tab after I started to debug:
set debug-from mainstartWARNING(CMD399-COR192-IMG54-COR307): ! Failed to start the target! Failed to resolve breakpoint expression "main"! Failed to demand load DWARF debugging information: section .debug_info, offset 0x3a71! Unexpected symbol ENUMERATION_TYPEWARNING(CMD407): Trying the entry point insteadwaitExecution stopped at breakpoint 1: 0x00011208In _start (no debug info)
Debugging works just in Disassembly and expressions won't work at all. The error ' Unexpected symbol ENUMERATION_TYPE ' seems odd cause it's a default debug entry of DWARF, isn't it?
So I need some suggestions. Same results from DS-5 5.23.1 & 5.25.0.
Thanks Marcus, for the update.It seems we will need to investigate this in more detail, so rather than trying to share code via this Community post, please open a Support Case using the "Support > Open a Support Case" option at the top of this page.Have you tried the latest (v5.29) version of DS-5?
Stephen
