Why gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu compiler does not support glibcxx_3.4.x and cxxabi_1.3.x version?How to fix this problem, thank you!
Hi experts,
    I need to connect Basler's camera via USB3.0 on the J7 EVM board. Basler provides the driver for the camera. I use the compiler gcc-arm-9.2-2019.12-x86_64-aarch64-none-linuk-gnu provided by TI. QT5.14.2 has been cross-compiled. In the camera test program, I added the camera library and reported the following error:
Qt is looking for glibc in the aarch64 directory, where the version of the library does not support GLIBCXX_3.4.21. Please help to see why the version of glibc in gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu can only support glibc2.18 at most. I downloaded the latest compiler from arm website(gcc-arm-10.2-2020.11-x86_64-aarch64-none-linux-gnu.tar.xz), which supports glibcxx_3.4.28, I found that libstdc++.so.6 of gcc-arm-9.2 and gcc-arm-10.2 both point to libstdc++.so.6.0.28 library. Why use the same library and support different versions of glibcxx and cxxabi? I can't support using the latest compiler right now, because I need other Ti libraries in my project. I would like to ask, what can solve the problem that gcc-arm-9.2 version can support glibcxx_3.4.28 and cxxabi_1.3.10, any help would be appreciated, thank you!
See the versions supported by glibc in the gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu directory as follows:
root@ubuntu:/home/qkl# cd gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu/
root@ubuntu:/home/qkl/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu# cd aarch64-none-linux-gnu/
root@ubuntu:/home/qkl/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu/aarch64-none-linux-gnu# strings lib64/libstdc++.so.6 | grep GLIB
GLIBC_2.17
GLIBC_2.18
GLIBCXX_FORCE_NEW
GLIBCXX_DEBUG_MESSAGE_LENGTH
nanosleep@@GLIBC_2.17
fchmodat@@GLIBC_2.17
fchmod@@GLIBC_2.17
pthread_mutex_lock@@GLIBC_2.17
dgettext@@GLIBC_2.17
__wcsftime_l@@GLIBC_2.17
See the versions supported by CXXABI in the gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu directory as follows. It is empty. why?
root@ubuntu:/home/qkl/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu/aarch64-none-linux-gnu# strings lib64/libstdc++.so.6 | grep CXXABI
libstdc++.so link to libstdc++.so.6.0.28 as follows:
root@ubuntu:/home/qkl/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu/aarch64-none-linux-gnu# ls -all lib64/libstdc*
-rw-r--r-- 1 qkl qkl 59098440 Dec  9  2019 lib64/libstdc++.a
-rw-r--r-- 1 qkl qkl 17879644 Dec  9  2019 lib64/libstdc++fs.a
lrwxrwxrwx 1 qkl qkl       19 Dec  9  2019 lib64/libstdc++.so -> libstdc++.so.6.0.28
lrwxrwxrwx 1 qkl qkl       19 Dec  9  2019 lib64/libstdc++.so.6 -> libstdc++.so.6.0.28
-rwxr-xr-x 1 qkl qkl 22996688 Dec  9  2019 lib64/libstdc++.so.6.0.28
-rw-r--r-- 1 qkl qkl     2400 Dec  9  2019 lib64/libstdc++.so.6.0.28-gdb.py
See the versions supported by glibc in the gcc-arm-10.2-2020.11-x86_64-aarch64-none-linux-gnu directory as follows:
root@ubuntu:/home/qkl/tool# cd gcc-arm-10.2-2020.11-x86_64-aarch64-none-linux-gnu/aarch64-none-linux-gnu/
root@ubuntu:/home/qkl/tool/gcc-arm-10.2-2020.11-x86_64-aarch64-none-linux-gnu/aarch64-none-linux-gnu# strings lib64/libstdc++.so.6 | grep GLIB
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBCXX_3.4.16
GLIBCXX_3.4.17
GLIBCXX_3.4.18
GLIBCXX_3.4.19
GLIBCXX_3.4.20
GLIBCXX_3.4.21
GLIBCXX_3.4.22
GLIBCXX_3.4.23
GLIBCXX_3.4.24
GLIBCXX_3.4.25
GLIBCXX_3.4.26
GLIBCXX_3.4.27
GLIBCXX_3.4.28
GLIBC_2.17
GLIBC_2.18
_ZNKSt14basic_ifstreamIcSt11char_traitsIcEE7is_openEv@GLIBCXX_3.4
_ZNKSs11_M_disjunctEPKc@GLIBCXX_3.4
See the versions supported by CXXABI in the gcc-arm-10.2-2020.11-x86_64-aarch64-none-linux-gnu directory as follows:
root@ubuntu:/home/qkl/tool/gcc-arm-10.2-2020.11-x86_64-aarch64-none-linux-gnu/aarch64-none-linux-gnu# strings lib64/libstdc++.so.6 | grep CXXABI
CXXABI_1.3
CXXABI_1.3.1
CXXABI_1.3.2
CXXABI_1.3.3
CXXABI_1.3.4
CXXABI_1.3.5
CXXABI_1.3.6
CXXABI_1.3.7
CXXABI_1.3.8
CXXABI_1.3.9
CXXABI_1.3.10
CXXABI_1.3.11
CXXABI_1.3.12
CXXABI_TM_1
CXXABI_1.3
CXXABI_1.3.11
CXXABI_1.3.2
CXXABI_1.3.6
CXXABI_1.3.12
CXXABI_1.3.9
CXXABI_1.3.1
CXXABI_1.3.5
CXXABI_1.3.8
CXXABI_1.3.4
CXXABI_TM_1
CXXABI_1.3.7
CXXABI_1.3.10
CXXABI_1.3.3
root@ubuntu:/home/qkl/tool/gcc-arm-10.2-2020.11-x86_64-aarch64-none-linux-gnu/aarch64-none-linux-gnu# ls -all lib64/libstd*
-rw-r--r-- 1 7720 7720 54525806 Nov 20 09:12 lib64/libstdc++.a
-rw-r--r-- 1 7720 7720 13411614 Nov 20 09:12 lib64/libstdc++fs.a
lrwxrwxrwx 1 7720 7720       19 Nov 20 09:12 lib64/libstdc++.so -> libstdc++.so.6.0.28
lrwxrwxrwx 1 7720 7720       19 Nov 20 09:12 lib64/libstdc++.so.6 -> libstdc++.so.6.0.28
-rwxr-xr-x 1 7720 7720 21385504 Nov 20 09:12 lib64/libstdc++.so.6.0.28
-rw-r--r-- 1 7720 7720     2401 Nov 20 09:12 lib64/libstdc++.so.6.0.28-gdb.py
Best Regards,
Emily
