I have a scatter loading file that defines the stack as below:
ARM_LIB_STACK 0x00BFFFFFF0 EMPTY -0x20000 {}
In the compiled image, I can see these symbols (by running nm -g command):
00000000bffdfff0 A Image$$ARM_LIB_STACK$$ZI$$Base0000000000020000 A Image$$ARM_LIB_STACK$$ZI$$Length00000000bffffff0 A Image$$ARM_LIB_STACK$$ZI$$Limit
The common practice is to set SP to 0x00BFFFFFF0 in the system initialization code. But armlink_user_guide documents Image$$region_name$$ZI$$Limit as "Address of the byte beyond the end of the ZI output section in the execution region". It sounds like Image$$ARM_LIB_STACK$$ZI$$Limit should not be part of the stack. This is confusing. which address should be regarded as part of the stack, Image$$ARM_LIB_STACK$$ZI$$Base or Image$$ARM_LIB_STACK$$ZI$$Limit? Due to the stack alignment requirement, the SP can only be 0x00BFFFFFF0 in my case. Then Image$$ARM_LIB_STACK$$ZI$$Base is not correct. Obviously:
Image$$ARM_LIB_STACK$$ZI$$Limit - Image$$ARM_LIB_STACK$$ZI$$Base + 1 = 0x20000 + 1
if both of them are inclusive.
-Oscar
