What happens to the Instructions already in pipeline when interrupt occurs ?
Hello Community,
Recently I was going through some code and has this doubt.
My Pseudocode
CPSID I - Disable interrupts
Do critical work
CPSIE I - Enable interrupts
Do non critical work.
After I enabled interrupts and if there is pending interrupt , Does the exception handler will execute right after CPSIE I instruction ? What happens to the instructions that are already there in pipeline ?  I am looking for CM0/CM0+ behavior.
Regards.
Vijay.
