Cotex-M7 : Is there any hang case which TCMwait could make?
I am using Cortex-M7 Processor and long latency memory with ITCM and DTCM
I knew that TCM protocol defines multi-cycles TCMWAIT signal (I read Cortex-M7 TRM).
So, I implemented ITCMWAIT and D#TCMWAIT.
Now, I have the serious problem.
          The problem is  that
          - while Cortex-M7 did well, in the specific case, it hang.
             In that case, I couldn't connect to Cortex-M7 with TRACE-32 and both ITCMWAIT and D#TCMWAIT had been HIGH
Thank you for your words.
