Unable to determine offending instruction: usage fault illegal unaligned load or store cortex m7 keil mdk pro
Problem
Once in a blue moon (every ~500 hours of run time, non-deterministic) I am getting a Usage Fault/ Illegal unaligned load or store. Please, help me to trace the fault to actual offending instruction and extract additional info.
What have I done so far:
Per ARM AN209 (www.keil.com/.../apnt209.pdf) I have installed a hard fault handler.
extern C void HardFault_Handler(void)
__asm volatile
tst lr, #4 \n
ite eq \n
mrseq r0, msp \n
mrsne r0, psp \n
ldr r1, [r0, #24] \n
ldr r2, handler2_address_const \n
bx r2 \n
handler2_address_const: .word prvGetRegistersFromStack...Code
Values of the registers extracted from the exception stack frame are:
LR is 0x0803B131
PC is 0x0803A758
PSR is 0x01000000
// Extracted after printf executed
HFSR is 0x40000000 indicating Forced (I do not have a separate handler for UsageFaults)
CFSR is 0x01000000 indicating UsageFault, UNALIGNED access
xSPR is 0100 0003
MMFAR is 0
BFAR is 0
pc (0x0803A758) points to a dead loop of osRtxIdleThread.
This could not be the offending instruction, could it? What am I missing?
I have checked the RM0385 Reference manual, I see that the exception stack has been parsed properly.
@2001A198:
00000000 00000000 00000000 00000000   00000000 0803B131 0803A758 01000000
E25A2EA5
My system is:
Cortex M7 (STM32F746NG..)
Keil RTOS
Once the unit is stalled, I have connected to it using SEGGER J-Link/J-Trace for Cortex M (using Ozone), stopped the program, and examined the memory contents.
Unaligned access fault trap (UNALIGN_TRP) is disabled ( per reference it means that only multi-word instructions can generate this fault)
I read:
community.arm.com/.../debugging-a-usage-fault-for-an-unaligned-memory-access
www.keil.com/.../3777.htm (but no external SDRAM is used)
also I read:
medium.com/.../the-curious-case-of-unaligned-access-on-arm-5dd0ebe24965
stackoverflow.com/.../unaligned-access-causes-error-on-arm-cortex-m4
stackoverflow.com/.../what-is-non-aligned-access-arm-keil
stackoverflow.com/.../arm-unaligned-memory-access-workaround
