Help with programming STM32F103RCT6 board.
I have bought  this Cortex M3 board. Now I want to program it through jtag.
So I bought this wire. By using the USB to serial interface of my linux machine, I want to program the board.
I went to read the data sheet of board here[1]. In section 2.3.29, it is written:
The ARM SWJ-DP Interface is embedded, and is a combined JTAG and serial wire debug port that enables either a serial wire debug or a JTAG probe to be connected to the target. The JTAG TMS and TCK pins are shared respectively with SWDIO and SWCLK and a specific sequence on the TMS pin is used to switch between JTAG-DP and SW-DP.
So if my reading is correct, I will use the SWDIO and SWDCLK ports to try to tinker with the board. Or am I missing something grave here?
date sheet:www.componentschip.com/.../ARM-542.html
  • Are you asking if you can use a USB to serial adapter to interface with the SWD JTAG port on your board?  If so, the answer is NO.
    The RS-232 style serial communications interface provided by a USB to Serial adapter has dedicated TX and RX pins.  The JTAG serial interface uses a single pin, SWDIO, to both send and receive data.
    Larry
