Hi
Using STM32f4 Board, I am enabling MPU in between any code (simple program) always causing memory management fault on debugging fault that (
IACCVIOL) bit is set, It means
Attempting to execute an instruction from a memory region marked as Non-Executable
(XN).
why this problem occur with enabling MPU not by without using MPU?
Demonstrate the code for enabling MPU which you use in your program.
