Linker in gnu arm toolchain says "group ended without start" thought there is no such option in my build
shyam@shyam:~/projects/zynq/microzed/linux_source/Test_Chips$ make
make -C  /home/shyam/projects/zynq/microzed/linux_source/Test_Chips/../dev_tools/build
make[1]: Entering directory `/home/shyam/projects/zynq/microzed/linux_source/dev_tools/build'
Making lin/dbg version of sub-directory tools/ ...
make[2]: Entering directory `/home/shyam/projects/zynq/microzed/linux_source/dev_tools/build/tools'
Making lin/dbg version of sub-directory genmakefiles/ ...
make[3]: Entering directory `/home/shyam/projects/zynq/microzed/linux_source/dev_tools/build/tools/genmakefiles'
Building dbg version of 'genmakefiles' ...
make[4]: Entering directory `/home/shyam/projects/zynq/microzed/linux_source/dev_tools/build/tools/genmakefiles'
Building executable 'genmakefiles' ...
make[5]: Entering directory `/home/shyam/projects/zynq/microzed/linux_source/dev_tools/build/tools/genmakefiles/B_linjtag_dbg'
GCC_EXEC_PREFIX=/home/shyam/projects/zynq/microzed/linux_source/Test_Chips/../dev_tools/dk_lin/gcc_armgnu/lib/gcc/ TMPDIR=/inedatmp /home/shyam/projects/zynq/microzed/linux_source/Test_Chips/../dev_tools/dk_lin/gcc_armgnu/bin/gcc -mcpu=cortex-m4 -mthumb -Wall -gstrict-dwarf -gdwarf-3 -g -mfpu=fpv4-sp-d16 -mfloat-abi=softfp -O0 -lm -ldl   genmakefiles.o           -L/home/shyam/projects/zynq/microzed/linux_source/Test_Chips/../dev_tools/dk_lin/gcc_armgnu/lib   -Wl,-rpath  -o genmakefiles
/home/shyam/projects/zynq/microzed/linux_source/Test_Chips/../dev_tools/dk_lin/gcc_armgnu/lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: group ended before it began (--help for usage)
collect2: error: ld returned 1 exit status
make[5]: *** [genmakefiles] Error 1
make[5]: Leaving directory `/home/shyam/projects/zynq/microzed/linux_source/dev_tools/build/tools/genmakefiles/B_linjtag_dbg'
make[4]: *** [genmakefiles] Error 2
make[4]: Leaving directory `/home/shyam/projects/zynq/microzed/linux_source/dev_tools/build/tools/genmakefiles'
make[3]: *** [genmakefiles.dbg] Error 2
make[3]: Leaving directory `/home/shyam/projects/zynq/microzed/linux_source/dev_tools/build/tools/genmakefiles'
make[2]: *** [subdirs.dbg] Error 1
make[2]: Leaving directory `/home/shyam/projects/zynq/microzed/linux_source/dev_tools/build/tools'
make[1]: *** [subdirs.dbg] Error 1
make[1]: Leaving directory `/home/shyam/projects/zynq/microzed/linux_source/dev_tools/build'
make: *** [all] Error 2
Hi all,
as you can see there is no option for end group or "-)" in my build but the linker says such error.
Can you please help me if im missing something.
Regards,
Shyam Kumar Thella
