SVC instruction execution inside the hard fault handler
Hello everyone,
Processor : Arm Cortex-m4
For an experiment, I purposely triggering hard fault exception, by making T-bit in Execution Program Status Register to 0. The program execution control reaches hard fault handler.
Inside the hard fault handler I was triggering SVC instruction using "__asm volatile ("SVC #0");". After executing this line, system goes reset.
May I know the reason.
  • It is hard to say just from the description above. Do you fix the T-bit (via debugger?) after the Hard Fault?
    Looking at similar cases I found, there were suggestions to set breakpoint on the entry of the SVC handler to see if you ever even reach that point? If your target supports trace, getting an execution log could be invaluable.
    If this happening on a real MCU? It may be that there is additional logic triggering a reset if multiple hard-faults are occurring, as it detects something has gone wrong? (this is just a guess - I'm not aware of any particular device that does this).
  • static void printAdd(int var1, int var2)
    	printf("Sum %d\n",(var1 + var2));
    int main(void)
    	 * The Program Counter (PC) is register R15. It contains the current program address. On reset,
    	the processor loads the PC with the value of the reset vector, which is at address 0x00000004.
    	Bit[0] of the value is loaded into the EPSR T-bit at reset and must be 1.
    	 * The Cortex-M4 processor only supports execution of instructions in Thumb state. The following
    	can clear the T bit to 0:
    	• instructions BLX, BX and POP{PC}
    	• restoration from the stacked xPSR value on an exception return
    	• bit[0] of the vector value on an exception entry or reset.
    	Attempting to execute instructions when the T bit is 0 results in a fault or lockup.
    	* The processor enters a lockup state if a fault occurs when executing the NMI or HardFault
    	handlers. When the processor is in lockup state it does not execute any instructions. The
    	processor remains in lockup state until either:
    	• it is reset
    	• an NMI occurs
    	• it is halted by a debugger.
    	Note:
    	If lockup state occurs from the NMI handler a subsequent NMI does not cause the processor to
    	leave lockup state.
    	/* Function pointer 1, initialize with "printAdd" function with complier
    	 * (i,e) program counter is loaded with function name "printAdd" - 0x08000d19 address [PC 0th bit is 1 - Thumb State].  */
    	static void (*funcPtr1) (int,int) = printAdd;
    	/* Function pointer 2, initialize with "printAdd" function without complier
    	 * (i,e) program counter is loaded with 0x08000d18 address directly [PC 0th bit is 0 - Arm State].*/
    	static void (*funcPtr2) (int,int) = (void*) 0x08000d18;
    	/* call funcPtr1 - Thumb state */
    	funcPtr1(10,20);
    	/* call funcPtr2 - Arm state */
    	funcPtr2(10,20);
        /* Loop forever */
    	for(;;);
    void HardFault_Handler(void)
    	/* Print "Hard fault detected" */
    	printf("Hard fault detected\n");
    	/* Trigger SVC instruction */
    	while(1);
    /* SVC IRQ Handler */
    void SVC_Handler(void)
    	/* Inside SVC Handler */
    	printf("Inside SVC Handler\n");
    This is the test code I was using, for your reference.
    Other details
    HW : STM32F407VG
    IDE : STMCUBE
    LANGUAGE : C
    Output console :
    After this point executing SVC instruction, reset happened.
    As per the suggestion, I was set the breakpoint on the entry of the SVC handler and it is not reaching that point.
  • SVC from within a hard fault handler causes lockup on Cortex M cpus. I think the default behaviour on lockup is reset. I use Silabs EFM32 cpus, which have hardware options to not reset but simply stay in lockup. Yiu's Definitive Guide to M3/M4 includes commentary on lockup.
  • Thank you for your input, it was really helpful.
