If the R5's TCM is configured to reside at location 0x0000 0000 does it hold the exception vector table?
Thanks, Tom
The vector table resides at either 0x0 or 0xffff0000, defined by a pin at reset, and reflected in the V bit of the SCTLR:https://developer.arm.com/documentation/den0042/a/ARM-Processor-modes-and-Registers/Registers/System-Control-Register--SCTLR-
If TCM is at 0x0 and V bit is 0, then yes, you can place the vector table there (and this is a very common scenario). You may have reset behavior that starts from 0xffff0000, then enable and initialize TCM, then clear V bit to enable subsequent exceptions to be handled in TCM.
Hi Ronan and the forum,In the same context, I would like to know the behaviour of the system in the following scenario.What will happen if I configure a TCM after loading some data in that same region ?For example, I am loading some content at this address 0x00000000.Then, I am configuring ATCM region register to configure the same address (0x00000000).Here, what will happen to the content which I loaded before configuring TCM ?Thanks,
I believe the TCM memory would take precedence.
