Bit 22 in some LD/ST instructions (Cortex-A7)
I wonder if the bit 22 has some function in instructions like LDRH, STRH, LDRSBT, LDRD, ... (bits 27, 26, 25 = 0, 0, 0)?
                           22
c c c c 0 0 0  0  U 1  1  0 n n n n t t t t x x x x 1 0 1 1 x x x x STRHT<c> <Rt>,[<Rn>],{,#+/-<imm8>}  A1  A8.8.219
c c c c 0 0 0  0  U 1  1  1 n n n n t t t t x x x x 1 0 1 1 x x x x LDRHT<c> <Rt>,[<Rn>],{,#+/-<imm8>}  A1  A8.8.83
c c c c 0 0 0  0  U 1  1  1 n n n n t t t t x x x x 1 1 0 1 x x x x LDRSBT<c> <Rt>,[<Rn>],{,#+/-<imm8>}  A1  A8.8.87
c c c c 0 0 0 (1) U 1 (0) 0 1 1 1 1 t t t t x x x x 1 1 0 1 x x x xLDRD<c> <Rt>,<Rt2>,<label> LDRD<c> <Rt>,<Rt2>,[PC,#-0]  A1  A8.8.73
c c c c 0 0 0  P  U 0  W  0 n n n n t t t t (0) (0) (0) (0) 1 1 0 1 m m m m> LDRD<c> <Rt>,<Rt2>,[<Rn>,+/-<Rm>]{!} LDRD<c> <Rt>,<Rt2>,[<Rn>],+/-<Rm>  A1  A8.8.74
In some instructions, like LDR, STR, LDRB (bits 27, 26, 25 = 0, 1, 1) , I understand, it chooses between byte and word access.
  • Hello,
    bit 22 seems to basically indicate whether the addressing is immediate (i.e. displacement) or register (i.e. index).
    However, it sometimes indicates whether the access size is byte or not. in this case, the bit 25 specifies immediate or register.
    After all, the sort of load and store instructions should be considered for the bit 27 to 20.
    I am sorry for that this is not an answer.
    Best regards,
    Yasuhiko Koumoto.
  • Seems a fine answer to me.
    The arm arm has the rules about decoding in it and the ones you are interested in come under 'Extra load/store instructions'. They weren't there from the start but came in in ARMv4 or the double ones in ARMv5. They had to fit into the space left over by the earlier instructions so I wouldn't expect a fully consistent and easy decoding into bit meanings. Also if you are unsure about something you could try putting in a hexadecimal word and seeing how it disassembles..
  • Hello daith,
    I tried to dis-assemble the hexadecimal words.
    The below are the results.
       code            mnemonic                     bit22 inverted  mnemonic                comment
       e5901000        ldr     r1, [r0]             e5d01000        ldrb    r1, [r0]        " byte access
       e5801000        str     r1, [r0]             e5c01000        strb    r1, [r0]        " byte access
       e4b01000        ldrt    r1, [r0], #0         e4f01000        ldrbt   r1, [r0], #0    " byte access
       e4a01000        strt    r1, [r0], #0         e4e01000        strbt   r1, [r0], #0    " byte access
       e1901f9f        ldrex   r1, [r0]             e1d01f9f        ldrexb  r1, [r0]        " byte access
       e1801f92        strex   r1, r2, [r0]         e1c01f92        strexb  r1, r2, [r0]    " byte access
       e1d010b0        ldrh    r1, [r0]             e19010b0        ldrh    r1, [r0, r0]    " immediate
       e1c010b0        strh    r1, [r0]             e18010b0        strh    r1, [r0, r0]    " immediate
       e0f010b0        ldrht   r1, [r0], #0         e0b010b0        ldrht   r1, [r0], r0    " immediate
       e0e010b0        strht   r1, [r0], #0         e0a010b0        strht   r1, [r0], r0    " immediate
       e1f01f9f        ldrexh  r1, [r0]             e1b01f9f        ldrexd  r1, [r0]        " half word access
       e1e01f92        strexh  r1, r2, [r0]         e1a01f92        strexd  r1, r2, [r0]    " half word access
       e5d01000        ldrb    r1, [r0]             e5901000        ldr     r1, [r0]        " byte access
       e5c01000        strb    r1, [r0]             e5801000        str     r1, [r0]        " byte access
       e4f01000        ldrbt   r1, [r0], #0         e4b01000        ldrt    r1, [r0], #0    " byte access
       e4e01000        strbt   r1, [r0], #0         e4a01000        strt    r1, [r0], #0    " byte access
       e1d01f9f        ldrexb  r1, [r0]             e1901f9f        ldrex   r1, [r0]        " byte access
       e1c01f92        strexb  r1, r2, [r0]         e1801f92        strex   r1, r2, [r0]    " byte access
       e1d010d0        ldrsb   r1, [r0]             e19010d0        ldrsb   r1, [r0, r0]    " immediate
       e1d010f0        ldrsh   r1, [r0]             e19010f0        ldrsh   r1, [r0, r0]    " immediate
       e1c000d0        ldrd    r0, [r0]             e18000d0        ldrd    r0, [r0, r0]    " immediate
       e1c000f0        strd    r0, [r0]             e18000f0        strd    r0, [r0, r0]    " immediate
       e1b02f9f        ldrexd  r2, [r0]             e1f02f9f        ldrexh  r2, [r0]        " half word access
       e1a04f92        strexd  r4, r2, [r0]         e1e04f92        strexh  r4, r2, [r0]    " half word access
    Best regards,
    Yasuhiko Koumoto.
  • I've seen that.It looks like new command groups are added in best fit manner to keep the instruction set fragmentation low.
  • Thanks!
    There is something for me to chew for a while.
    BTW, what do you mean by "immediate"? I would expect to see some constant value in immediates.
    Also, funny to see that it's not byte/word access, but more like full size/half size access.
  • Hello,
    "immediate" means basically "base register + displacement" addressing such as "LDR r0, [r1,#immd]".
    To the contrary "index" means "base register + index" addressing such as "LDR r0,[r1,r2]".
    Best regards,
    Yasuhiko Koumoto.
  • I always thought of [r1,#imm] as being indexed, just as a constant index.
    But it would be more correct to call it immediate and the base register + index register for indexed mode.
    -There are a few more modes:
    pre-increment / pre-decrement (aka pre-update):
         ldr     r0,[r1,#10]!
    post-increment / post-decrement (aka post-update):
         ldr     r0,[r1],#10
    The following two are allowed in the older ARM architectures, but unfortunately not in thumb or thumb2:
         ldr     r0,[r1,r2]!
         ldr     r0,[r1],r2!
    -The post-update would have been particularly useful for me, particularly when being able to use them with LSL, LSR and ASR#16.
    But as the Cortex is clocked higher, it will still outperform the older architectures even when adding the extra add instruction (which is "for free" on the Cortex-M7 by the way).
  • I, myself, am accustomed with the convention used with many other processors:
    (6502, 68xx 68xxx, VAX11, PDP11, 8085, x86, PPC (I recall), ...)
    stc; set carry - no operands => implied
    ldr r, #val; the value 'val' is loaded into r - immediate
    ldr r, address; the value in address 'address' is loaded into r - absolute
    ldr r1, r2; the value of r2 is loaded into r1 - register(-direct)
    ldr r1, [ r2]; the value pointed to by r2 is loaded into r1 - register indirect (or indexed)
    ldr r1, [r2, #val]; the value pointed to by (r2 + #val) is loaded into r1 - indexed
    ldr r1, [PC, #val]; the value pointed to by (PC + #val) is loaded into r1 - (PC-)relative
    ldr r1, [r2++]; the value pointed to by r2 is loaded into r1, then r2 is incremented - indirect (or indexed) post-increment
    The '[ ]' (sometimes '( )') usually means indirection, so
    ldr r1, [r2], #imm would mean that imm would be added to the number pointed to by r2 and the result is loaded into r1.
    (= add r1, [r2], #imm)
    I don't recall encountering such instruction (whereas the 'add'-version is very familiar).
    The ARM instruction set is, however, quite different also in philosophy, so different naming convention is
    quite understandable.
  • Hello jensbauer,
    thank you for your comments.
    If we consider about the pre-indexed or post-indexed, it would be reasonable to take the immediate for the index.
    Therefore, we should call it as the immediate indexing or the register indexing, shouldn't we?
    Best regards,
    Yasuhiko Koumoto.
  • Hello,
    in legacy (or so called CISC) processors, the load or the move instruction included all addressing modes.
    However, at RISC processors, it have come that the load and the move are thought different functions.
    The move is used for the immediate or the register addressing.
    The load (or store) is used for the memory addressing.
    This would come from the load/store architecture.
    The memory addressing will form "base register + immediate index" or "base register + (index register with shift)".
    From the RISC view point, it would not be strange and it would be even normal.
    The ARM specific feature would be that the memory addressing had the pre-indexed or post-indexed mode".
    I am sorry but I cannot understand the meaning of "add r1, [r2], #imm".
    ldr r1, [r2], #imm
    would mean the following sequence because it was the post-indexed.
    1) load a memory contents of [r2] into r1
    2) add #imm to r2.
    This would be simllar to the legacy processer's notation of "ldr r1,[r2++]".
    In the "[r2++]" case, the incremented value is only the access size (i.e. 1 for byte, 2 for half-word and 4 for word).
    In the ARM case, the indexing is generalized to be able to add any value specified by #imm.
    Best regards,
    Yasuhiko Koumoto.
    I agree. If we do that, then there will be no doubt what we mean. I will start practicing this.
  • With "ldr r1, [r2], #imm = add r1, [r2], #imm" I mean the architectures I'm more familiar with, not in "ARM language".
