I applied for a FastModel license for A15 CPU yesterday , but I can’t download it, it’s status is “Awaiting Fulfillment”.
There is trick that, I used another account to apply license for the same PC host (MAC is same), for another A9UP CPU type a week ago, the license is OK.
Is there any problem with my license? Is the problem caused by that I used the same MAC for two licenses?
The system should fail at the point of download if you try to reuse the same MAC address. The error message will say the MAC address has already been used, not "Awaiting Fulfilment." Not sure what is going on there. I just tried it and didn't have any issue. In any case, the eval license you will get via license.support@arm.com will work for any of the models. You can download the full Fast Models library at developer.arm.com/.../fast-models.
The license status is from :https://developer.arm.com/support/licensing/view
Like the pic before, it's Awaiting Fulfilment.
When the button "View", and download , it return "The license is not yet available. Please try again later."
Will need your host ID or license serial number to troubleshoot this. Send it through to license.support@arm.com along with a link to this conversation.
