C164- DPPx: how to find data in Memory window???
Dear Sirs!
I would like to observe data in Memory window. For example this line of code was build from the compiler:
000002F4 F2F50AA2 MOV R5,DPP2:0x220A
Where content of DPP2 is '3'.
Does DPP2:0x220A means ( 3 <<14) | 0x220A ?
Result would be 0xE20A ??
F2F50AA2 says to me the Address 0xA20A will be read...(0x220A - 0x8000 = 0xA20A???)
in the memory window of the Debugger the contents of these addresses are just 0x00!?
How can I take a look at the right addresses?
Please write an answer to my Question!
hannes
  • Real address is 10 bit DPP2 value + 14 bit offset.
    DPP2=0x03      OFFSET=0x220A
    1100'0000'00     10'0010'0000'1010
    that results in
     1100'0000'0010'0010'0000'1010
       3   0  ' 2    2    0    A h
       = 30'220Ah
    See also
    http://www.keil.com/forum/docs/thread3063.asp
    where we have disussed the topic
    and
    users manual
    "Override Data Page Pointers"
    Hope this helps
    Stefan
  • Thanks!
    ...but can You explain why the address in disassembly window (also in HEX-File) is 0xA20A (..0AA2..)??
    hannes
  • Hi Stefan,
    and
    Where content of DPP2 is 3
    This is correct, address is 0xE20A.
    In fact the correct formula would be
    ((DPP2 & 0x03FF) << 14) | (0x220A & 0x3FFF)
    you will obtain 0x30220A only if you set DDP2 to 0x00C0.
    Ciao
    Bruno
  • Bruno,
    you are absolut right.
    If I said 10 bit value, I did the wrong shifting.
    Hannes,
    Sorry for confusion, that was my mistake.
    PageOffset(14bit).....xx10 0010 0000 1010
    DPP2 = 10b.............1010 0010 0000 1010
    (10bit)
    DPP2value=3h =>.....xxxx xx00 0000 0011
    Address:
    00 0000 0011 xx xxxx xxxx xxxx
    xx .xxxx xx10 10 0010 0000 1010
    00 0000 0011 10 0010 0000 1010
    = 00'E20Ah
    Stefan
  • Hi Bruno,
    that's me again. Now I am confused.
    Assuming the DPP2 value is 5=101b.
    PageOffset from Hannes is 0x220Ah.
    For DPP2= 10b
    I got with my calculating:
    00 0000 0101 00 0000 0000 0000
    00 0000 0010 10 0010 0000 1010
    00 0000 0111 10 0010 0000 1010 = 01'E20Ah
    I got with your calculating:
    00 0000 0000 10 0010 0000 1010 because mask
    00 0000 0101 10 0010 0000 1010 = 01'620Ah
    With this your formula seems wrong (?),
    it would use DPP0 instead of DPP2 and
    I would recalculated as:
    PageOffset & 0x3FFF obtain 12-bit value (Offset inside the page)
    OR (DPP_Nr<<14) get 14 bit value with DPP0=00b....DPP3=11b to be able to address 16K, DPP is start address inside segment (64k).
    ((DPPxValue & 0x3FF)<<14) obtain 10-bit value and shift it right.
    That courses the following formula
    ((DPPxValue & 0x3FF)<<14) | ((PageOffset & 0x3FFF) | (DPP_Nr<<14))
    I was sure you have to calculate the DPP_Nr
    with DPP0=00b, DPP1=01b, DPP2=10b, DPP3=11b
    at bitpositions 14 and 15 (start counting from 0).
    That would make more sense to me, because
    inside a 64K segment the page pointer must
    give the startaddress of a 16K area.
    If I something misunderstood,
    enlighting is welcome.
    Stefan
  • Hello Stefan,
    the C167 hardware compose the 24 bit address using the formula I gave you, but this does not mean that it really makes the shift and mask operations written into the formula; operations are just done into a dedicated part of the C167 hardware.
    Bits 14 and 15 of the PageOffset just select the DPPx register to be used to compose the full 24 bit address.
    Imagine the C167 hardware that composes the 24 bit address: it should be very similar to this schematic diagram
                    4 to 1 Multiplexer
                DPP0 --->       |
                DPP1 --->  \    |
                        |   o-- >----+
                DPP2 --->       |    |
                DPP3 --->       |    |
          2 bit selector    |        +--> Address bits 14..24
          Bits 14 and 15 >--+        +--> Address bits 0.13
         from PageOffset             |
        Bits 0..13 from PageOffset >-+
    Bits 14 and 15 just select the right DPPx, they are not used to produce the final 24 bit address.
    So, the right calculation is
    <--DPPx----> <---PageOffset-->
    Hope I was clear enough, ciao
    Bruno
    P.S. A big hello to Hannes...
  • Hi Bruno, hi Hannes,
    I am shamed, but enlighted.
    Bruno, no doubt anymore. It is all correct.
    I read with your explanation the users manual very carefully again.
    (I misinterpreted the fig.4-14 in the
    systems users manual XC167CI V1.1 2002
    page 4-34 ..... page 4-36,
    where bits 14 and 15 are shown separated)
    Correct formula by Bruno is
    BTW: Thanks for invest time and make a nice
    graphic, which make it clear to me.
    Stefan
  • Hello Mr. Coppi!
    ... it's nice to know You are there watching the 'S.O.S' messages.
    Please could You explain how the compiler translates?: I looked at this line of code:
    and wondered why the address is 0xE20A, I expected 0xA20A, -the difference is one page 0x4000, I think. But how does the C164 know that? How is the right DPPreg (DPP2) used (because everywhere a DPP is used, a 'F' is written at the place where the registers are addressed: F2F50AA2).
    ...I don't know if i asked You times ago, but i am confused everytime i use the PWM (CapCom6): the CC6x register seems to be a shadow register because the duty cycle only changes after setting STE12. All the Manuals say it's not. Also Errata sheets tells nothing other. Do You know something? (I used B and C steps).
    Best Regards hannes
  • Ciao Hannes,
    I ALWAYS read the forum (at night), even if I answer questions very seldom.
    Well, I'm not sure I understand your question; you want to know WHERE is the binary field that selects the DPPx into that opcode? It is in bits 14 and 15 of the address:
    F2F5 is the opcode itself
    A20A is the address
    A20A = 10.10 0010 0000 1010
    the leftmost 2 bits (10.) are the DPP selection bitfield (in this case 10. = 2, so DPP2 is selected), the remaining 14 bits (.10 0010 0000 1010) are the address within a 16K page.
    I can only guess: during the code generation, the compiler 'knows' how DPP registers are used and keeps track of their content.
    So, when it generates a memory access instruction, first of all it looks at the DPP registers and composes the instruction using the correct bitfield to address the required DPP.
    Anyway, things can be different for each memory model and I'm not the compiler writer, this is only an hypothesis and it's better you ask Reinhard Keil directly to have further informations about compiler technology.
    About CC6x registers: they have shadow latches.
    C164 User's Manual V3.1, 2002-02, page 17-22
    Shadow Latches for Synchronous Update
    The timer period, offset, and compare values are written to shadow latches rather than
    to the actual registers. Also the initial value bits CCxI/COUTxI in register CC6MCON are
    equipped with shadow latches. Thus the values for a new output signal can be
    programmed without disturbing the currently generated signal(s). The transfer from the
    latches to the registers is enabled by setting the respective shadow latch transfer enable
    bit STEx in register CTCON.
    If the transfer is enabled the shadow latches are copied to the respective registers the
    next time the associated timer reaches the value zero (either being cleared in edge
    aligned mode or counting down from 1 in center aligned mode).
    When timer T12 is operating in center aligned mode it will also copy the latches (if
    enabled) if it reaches the currently programmed period value (counting up).
    After the transfer the respective bit STEx is automatically cleared.
    Note: While T12/T13 is running, the shadow latch transfer is controlled by bit STE12/13.
    While T12/T13 is stopped, the shadow latch transfer is done automatically if bit
    CTRES12/13 is set; otherwise those latch values are not transferred.
    Note: If a new compare value is written to the shadow latches while T12 is counting up,
    the new value must be smaller than the current period value. Otherwise no more
    matches will be detected and the output signals will no longer change.
    If a compare value is written, while T12 is counting down, any value may be used.
    This same description is present even in V1.0 manual, page 17-19.
    Have fun, ciao
    Bruno
