Timer accuracy
I configured a timer to generate a signal every 1 ms.
See below my code about the timer:
TIM_DeInit(TIMx);  // TIM1 Deinitialization *
TIM_InitStructure.TIM_Mode                       = TIM_OCM_CHANNEL_1;
TIM_InitStructure.TIM_OC1_Modes          = TIM_TIMING;
TIM_InitStructure.TIM_Clock_Source       = TIM_CLK_APB;
TIM_InitStructure.TIM_Clock_Edge         = TIM_CLK_EDGE_FALLING;
TIM_InitStructure.TIM_Prescaler          = 0xEF; // period = 5us
TIM_InitStructure.TIM_Pulse_Length_1 = 0xC8; // cycle of 200 period => cycle = 1ms
TIM_Init (TIMx, &TIM_InitStructure);
And the statements inside timer's interrupt:
void TIM1_IRQHandler(void)
        // port 3 pin 7 activated
        P37_1;
        // ACK interrupt
        TIM_ClearFlag(TIM1, TIM_FLAG_OC1);      // clear Output Compare 1 flag
        TIM_CounterCmd(TIM1, TIM_CLEAR);        // Reset TIM1 Counter
    VIC0->VAR = 0xFF;                                        // write any value to VIC0 VAR
BUT my oscilloscope measured a period of 1.03 ms instead of the 1ms expected.
Normally to generate a pulse every 1.03 ms the TIM_Pulse_Length_1 should be set to 0xCE.
As you can see, the difference between 0xCE and 0xC8 is big.
What can be the cause of this timer's inaccuracy ?
> Problem in PLL configuration ?
> Problem of crystal ?
> Problem in timer configuration ?
Has someone the same problem ?
In advance, thank you
