Hi Everybody, I'm experimenting with Infineon's XC161CJ-controller on an Infineon SK-XC16x starter kit. Most of my routines work now, except the I2C-routines. Sending of data works OK, but the errors occur when I want to receive data. Has anybody on this forum written I2C-routines for this controller? And if so, are you willing to share them? Thanks in advance. :) Kind Regards, Dennis Ebben
Hello Stefan, I am working with the I2C module of the XC161. Could it be possible to publish the low level routines somewhere on the WEB ? Thanks for your help David
Hi David, unfortunately not. But it is no problem to mail it, if you leave your e-mail here. Stefan
Hello Stefan, You can send the I2C routines to this address : davidbrev(at)yahoo.se Thank a lot for your help. David
Hi David, have it done! Check your account. Stefan
Hello Stefan: I'm working with XC167CI, and I'm getting some problems with the I2C routines. I'm only using it to communicate with a 24LC EEPROM, I used SPI and uWire to do this (93 and 95 series EEPROMs) and I2C software implementation is new to me. I'd be gratefull to you if you'd send to me your routines, wich I think will work (more or less) with the XC167CI due to architechtural similarities. My address is alfersi(at)lavhek.com Thanks a lot.
Hi Alberto, no problem. Leave your e-mail here, I will send you asap. Stefan
Sorry Alberto, I was read over your e-mail account. Driver I mailed to you. Check your account. Stefan
Dear Stefan and Friends, I am also working on an I2C – EEPROM(FM24C256) application for XC167, so far I have used Dave generated code but I got into trouble. Writing works fine but reading…not. Stefan, is it possible for me to share your I2C code? My e-mail address is ai(at)home.se With best regards, Atsushi Ishii
Hi Stefan and freinds, I am using the iiC module of the XC161 to communicate to external eeprom. Please can i share you iic files? email:kaleem20@yahoo.com Thanks in advance Kaleem.
Hi Stefan! I'm also working with a XC161 and i didn't get my routines working. Can you please send me the routines. Thank you in advance. email: tinytove@gmx.at
Hi Ludwig, I sent it. Sorry for delay. Stefan
Hello Stefan, i have the same problem XC167 with 24LC16B serial eeprom. would you please send me the routines? Thomas
Hi Thomas, that is no problem, but I need your e-mail address to send it. Best regards - Stefan
Hello Stefan, my email address is thomas.schneider@berger-lahr.com thank you Thomas
