Hi Everybody, I'm experimenting with Infineon's XC161CJ-controller on an Infineon SK-XC16x starter kit. Most of my routines work now, except the I2C-routines. Sending of data works OK, but the errors occur when I want to receive data. Has anybody on this forum written I2C-routines for this controller? And if so, are you willing to share them? Thanks in advance. :) Kind Regards, Dennis Ebben
Hi Thomas - done !! Stefan
Hi Stefan, could you (or someone who have also the code) please send me IIC-code? best regards, Karl E-Mail:koarl70(at)gmx.at
Hello Stefan: I'm working with XC167CI and want to change my bit banging routines from C 167 CS to the new hardware IIC Module. Reading the treads about this theme, I want to ask you if you could please send me the routines to use the IIC hardware. Thanks a lot! christian.winkler@winkler-urach.de Christian
Hi Karl, hi Christian, Do it in some minutes. Sorry for delay, I was on vacation. Stefan
Stefan, is it possible to share your I2C code? My e-mail address is georg(at)eunet.yu With best regards, Gyoergy Dozsa
I'm working on a Multimaster-system with 2 xc167 connected via i2c bus and i think i have a timing problem becouse the system is not very stable. If anybody got a working multimastersystem it would be nice to share some code with me. Thanks peter.scheuermann@ies-systems.com
Dear Stefan as many others I have problems to get the I2C routines on the XC161CS-32F working. I would appreciate if you could share your code. My email:dhandzic@plantron.se
Hello Dirk, I sent it, please check your account. Stefan
Really nice to see that this topic is still interesting for a lot of people. :)
Hallo Stefan, Könntest Du mir den Low-Level-Treiber von Infineon auch zukommen lassen. Habe auch Probleme den I2C-Bus ans laufen zu bekommen. Email: m.stahl@moba.de Danke im vorraus. Dear Stefan could you share your code. I have also some problems with the i2c-routines. email: m.stahl@moba.de Best regards
Hi Michael, I sent it. With german remarks ;-). Check your account. Stefan
hello, i'm working with xc167 an also had many problems with i2c. is it possible to share your code an send it to me? thanks a lot. e-mail: mo@mimot.de michael
Hi Michael, done.
Hi Stefan, although this thread is over 18 months old now, today I experienced exactly the same problems while implementing a serial eeprom driver. So, may I humbly ask you for your routines too? Thank you very much in advance. My email is uwe.roth@web.de Uwe
Hi Uwe, the routines are based on the hardware implemented I2C module of XC16x devices. So I am not sure, whether they would be usefull to you. If you want them still, however, I see no problem to mail them to you. Let me know Stefan
