Launch of ARM DS 2023.0 hangs at "Checking existing product setup..." in Product Setup dialog
I have a new installation of ARM Development Studio 2023.0. I haven't gotten to the point of requesting a 30-day evaluation license. Immediately when launching the program, the product hangs with the following dialog:
Any help would be greatly appreciated!!
  • I have a few more data points.
    • I can install the same software on another Windows 10 Pro / 64-bit workstation that has gone though less S/W installs and de-installs, no VMs, no WSL, etc. and it skips the "Checking existing product setup..." dialog and goes directly to the "Select a license" dialog.
    • I can run that machine in safe mode w/ networking and it works
    • Running on my normal workstation, even in safe mode w/ networking does not work.
    • I've repaired the installation without effect.
  • I was able to install the S/W on a clone of the C: drive dated 4/19/22, so some actions in the interim have corrupted something.
    It would really be helpful if a software engineer familiar with the beginning of the ARM installer could look in the S/W to see what it might be waiting for.
  • If you delete the workspace that is being created (probably C:\Users\<username>\Development Studio Workspace), and restart the IDE does this resolve the issue?
    Was this workspace used by a previous version of the tool?
  • Thank you for your comment. On your suggestion, I deleted the workspace and the problem remains. That said, ARM has put a a file called .log in the .metadata directory that contained this tidbit:
    !SESSION 2023-08-14 18:29:47.426 -----------------------------------------------
    eclipse.buildId=unknown
    java.version=11.0.9.1
    java.vendor=Oracle Corporation
    BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
    Command-line arguments:  -os win32 -ws win32 -arch x86_64
    !ENTRY org.eclipse.core.jobs 4 2 2023-08-14 18:29:50.091
    !MESSAGE An internal error occurred during: "Checking existing product setup...".
    !STACK 0
    java.lang.NullPointerException
    	at com.arm.licensing.license.LicenseFile.validateAll(LicenseFile.java:221)
    	at com.arm.licensing.license.reader.LicenseReader.getValidLicenses(LicenseReader.java:255)
    	at com.arm.licensing.ui.wizard.CheckExistingSetupPageViewModel.startCheck(CheckExistingSetupPageViewModel.java:67)
    	at com.arm.licensing.ui.wizard.ui.CheckExistingSetupPage$CheckExistingSetupJob.run(CheckExistingSetupPage.java:75)
    	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
    One more data point: I installed v2022.2 and immediately got to the licensing dialog. So, there appears to be some interaction between my workstation post 4/19/22 and v2023.0. When I start v2022.2, the Development Studio Workspace/.metadata folder is created without the .log file.
  • Thank you for this - the Java version seems OK (same as my set up anyway).
    I can't replicate your scenario, but I will share this log with the development team.
  • If you delete the below folders and restart the IDE, does it resolve the issue?
    C:\Users\<user>\AppData\Roaming\arm\ds\<version>
    C:\Users\<user>\AppData\Roaming\arm\ds\licenses
    Probably also a good idea to delete the workspace folder (again).
  • I deleted the 2023.0 folder in C:\Users\<user>\AppData\Roaming\ARM\ along with the workspace folder. I relaunched 2023.0 and obtained the same result (hang). Another .log file was created with the similar entries. It appears that a call to validateAll is being performed with a NULL pointer because no licenses have been set up yet. It should be an easy fix.
  • Hi again Ken,
    Apologies for the ongoing trouble.
    It may be overkill, but perhaps an uninstall, delete the entire /AppData/Roaming/Arm/ds folder, and reinstalling, may be the quickest solution?
    Regards, Ronan
  • I deinstalled both 2022.2 and 2023.0, and deleted the Roaming/Arm folder, which had entries related to those two installs plus an old DS-5 install. I deleted the Development Studio Workspace folder, rebooted and installed 2023.0. Starting 2023.0 still results in a hang.
  • Like many systems, I have an environment variable "LM_LICENSE_FILE" set to "C:\FlexLM\license.dat". On a hunch, I renamed the "license.dat" file to something else and created an empty "license.dat". 2023.0 launched successfully, being rewarded with the expected "Add License" dialog:
     I added one comment line:
    # IMPORTANT
    ...to "license.dat" and received the "Activate product" dialog:
    I removed the comment and substituted the first "feature" in the file, which happened to be for ModelSim:
    INCREMENT msimcompare mgcld 2023.120 30-mar-2024 0 CFC395FD7C6058EB16C8 \
        VENDOR_STRING=CD6B950A HOSTID=FLEXID=9-72c52260 SN=283629548 \
        SIGN2="101F FA0D 8C47 C6FC 46B9 AAD1 6DAB BE9E 9671 B790 17CB 9032 \
        D99A 05CA C53C 1D09 5F30 3424 4F2D 5B59 0431 90F2 C45A B7AB BA48 D0AB \
        B8AC D045 5B42 BC37"
    ...and got the above "Activate product" dialog. Lastly, I put both the comment and the feature in the same file thus:
    # IMPORTANT
    ...and got the usual hang dialog:
    Hopefully, that will give your development engineers enough to replicate and/or fix the issue.
  • Hi again Ken,
    Thanks for this information - yes, LM_LICENSE_FILE is searched for a license (as is ARMLMD_LICENSE_FILE).
    I suspect the lack of an Arm DS license therein caused this issue.
    I'll update the development team.
    Hope you can now proceed with the tools.
    Regards, Ronan
  • Perhaps. If the ARM DS feature isn't the first feature, I fear that the software will hang.
  • Hi Ronan. I successfully applied for a 30-day evaluation license for 2023.0, but I fear that if I exit DS, I won't get back in. Will I be emailed either a product activation code or a text file that I can include in my "license.dat" file? TIA!
  • Open Help > License Manager, and you will see where the license file is created (should be in AppData). You can make a copy of this if necessary.
