Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
Assertion of IRQS is not causing calling of ISR
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Lokesh Kumar
over 12 years ago
Note: This was originally posted on 4th September 2012 at
http://forums.arm.com
With my current flow, when I am asserting legacy nIRQ I am able to jump to ISR, but not when asserting IRQS[0].
I have enabled interrupts as below
[size=2]CPSIE ifa, #18
and configured [size=2]Interrupt Security ([/size][/size][size=2][size=2]ICDISR), [size=2][/size][/size][/size][size=2][size=2][size=2][size=2]Interrupt Edge Trigger Config ([/size]ICDIF),[size=2]Interrupt Priority (ICDIPR)[/size][/size][/size][/size],[size=2]Interrupt Target Processor (ICDIPTR),[size=2]Interrupt Enable (ICDISER),[size=2]Interrupt Priority Mask (ICCPMR),[size=2]Interrupt Binary Point (ICCBPR),[size=2]Interface Control Register (ICCICR),[size=2]Distributor Control Register (ICDDCR)
Am I missing something?
Is something separate need to be done, when using IRQS interrupts?
Lokesh
[/size][/size][/size][/size][/size][/size]
Lokesh Kumar
over 12 years ago
ttfn,
I don't these registers in latest spec, they are removed
DDI0407H_cortex_a9_mpcore_r4p0_trm.pdf
As per programming part there should be same set of programming of registers mentioned above for both nIRQ and IRQS.
Since for nIRQ ISR is getting called, but not in the case of IRQS?
Is there any difference in the way of programming in nIRQ and IRQS?
If you need I can share these registers programming code.
Lokesh
Cancel
Vote up
0
Vote down
Cancel
Lokesh Kumar
over 12 years ago
ttfn,
Is that vector address will be different for IRQS[0] compared to nIRQ?
If so what is logic to derive vector address for IRQS[0].. IRQS[n]?
For nIRQ as suggested I am using base address + 0x18
VecTable
LDR pc, [pc,#0x18]
Is this same same for all IRQ or different for different IRQS?
Cancel
Vote up
0
Vote down
Cancel
Lokesh Kumar
over 12 years ago
Note: This was originally posted on 5th September 2012 at
Hi ttfn,
Yes you are right I am using cortex A9 MP core
Here is what I am configuring
;;; -Interrupt Security (ICDISR) (ICDISR0 is banked per processor)
; Define the security for this SPI interrupt
[ :DEF:VERBOSE
MESSAGE "Setting Interrupt Security\n"
LDR r2, =0x00000000 ; 1 = non-secure, 0 = secure
ADD r3, r11, #0x80
MOV r0, #0
int_secure_loop
STR r2, [r3]
ADD r0, r0, #0x1
ADD r3, r3, #0x4
; CMP r0, #0x08 ;#NUM_INT_LOOPS ;only need 8 times
CMP r0, #NUM_INT_LOOPS
BNE int_secure_loop
;;; -Interrupt Edge Trigger Config (ICDIFR)
[ :DEF:VERBOSE
MESSAGE "Setting Interrupt Trigger Cfg\n"
LDR r2, =0xffffffff ; 1 = edge, 0 = level
ADD r3, r11, #0xc00
MOV r0, #0
int_edge_cfg_loop
STR r2, [r3]
ADD r0, r0, #0x1
ADD r3, r3, #0x4
; CMP r0, #0x10 ;#NUM_INT_LOOPS
BNE int_edge_cfg_loop
;;; -Interrupt Priority (ICDIPR)
[ :DEF:VERBOSE
MESSAGE "Set Priority (greater than 0 to avoid masking)\n"
ADD r3, r11, #0x400
LDR r1, =0x08080808 ;; just make all priorities the same for this test
MOV r0, #0
set_pri_loop
; STR r1, [r3, #0x4]
STR r1, [r3]
ADD r0, r0, #0x1
ADD r3, r3, #0x4
BNE set_pri_loop
;;; -Interrupt Target Processor (ICDIPTR)
; Define the target for this SPI interrupt
[ :DEF:VERBOSE
MESSAGE "Setting Interrupt Targets\n"
; --- For example purposes, we'll have one processor as an individual target per interrupt
LDR r2, =0x01010101 ; See GIC Arch spec : one byte per interrupt : 1 = CPU0, 2 = CPU1, 4=CPU2, 8=CPU3
ADD r3, r11, #0x800
MOV r0, #0
int_target_loop
STR r2, [r3, #32] ;; Int ID's 0-31 are banked per CPU and not programmed for target processors
ADD r0, r0, #0x1
ADD r3, r3, #0x4
BNE int_target_loop
;;; --------------i------------------
;;; -Interrupt Enable (ICDISER)
; Now we need to enable the intterupts
[ :DEF:VERBOSE
MESSAGE "Enable Interrupts\n"
LDR r2, =0xffffffff
ADD r3, r11, #0x100
MOV r0, #0
set_enable_loop
; STR r2, [r3, #0x4]
STR r2, [r3]
ADD r0, r0, #0x1
ADD r3, r3, #0x4
; CMP r0, #0x4 ;#NUM_INT_LOOPS
BNE set_enable_loop
; Per CPU Config
; r10 = IC_INT_BASE
;;; -Interrupt Priority Mask (ICCPMR)
[ :DEF:VERBOSE
MESSAGE "Interrupt Priority Mask register\n"
LDR r1,[r10, #0x04]
CMP r1, #0
BNE fail
MOV r1, #0xf8 ; set priority reg to allow all priority levels to reach CPU
STR r1, [r10, #0x04]
; MESSAGE "Check2\n"
;;; -Interrupt Binary Point (ICCBPR)
[ :DEF:VERBOSE
MESSAGE "Binary Point register\n"
MOV r1, #3
STR r1, [r10, #0x08]
;MESSAGE "Check3\n"
;;; -Interface Control Register (ICCICR)
[ :DEF:VERBOSE
MESSAGE "CPU Interface Control Register\n"
MOV r1, #0x1f ;enable the interface
STR r1, [r10]
;Enable the Interrupt Interface disables legacy nFIQ/nIRQ support.
;The nFIQ/nIRQ pins then become part of the IRQS bus input pins to the controller.
;;; -Distributor Control Register (ICDDCR)
[ :DEF:VERBOSE
MESSAGE "Distributor Control register\n"
; The IRQS[] pins won't do anything without being enabled in the distributor
MOV r1, #0x1 ; enable SPI/PPI for Secure and Non-Secure modes
STR r1, [r11]
Please let me know if I am missing something.
Lokesh
Cancel
Vote up
0
Vote down
Cancel
Lokesh Kumar
over 12 years ago
Note: This was originally posted on 6th September 2012 at
Yes I have cleared it by following instruction
CPSIE ifa, #18
Which GIC spec you are referring.
I was going through IHI0048A_gic_architecture_spec_v1_0.pdf, but when I searched it on arm infocenter looks like second version of spec is available.
As per version 2
[0] EnableGrp1
[4:1] - Reserved
[5] FIQBypDisGrp1
[6] IRQBypDisGrp1
[8:7] - Reserved.
[9] EOImodeNS
So writing 0x1f also may not affect FIQ.
Anyway which document will be used for cortex A9 mp core.
Cancel
Vote up
0
Vote down
Cancel
Lokesh Kumar
over 12 years ago
If it's GCC v1 version than my configuration should be correct?
Please let me know if something is missing.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 12 years ago
You look like you have the full list of regs - so the question is what are you programming into those registers?
One thing you might want to check is the Pending Set/Clear registers. This will let you check whether the IC thinks the interrupt is pending (i.e. whether it sees the signal asserted).
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 12 years ago
You haven't said, but I'm guessing you are using Cortex-A9 MPCore - correct me if I guessed incorrectly.
So the nIRQ signals are the legacy interrupt signals. When the CPU interface is disabled (ICCICR.Enable=0) the nIRQ is connected directly to the core. All you need to generate an IRQ exception is clear CPSR.I and then assert the nIRQ signal (*).
When you enable the IC (ICCICR.Enable=1 & ICDDCR.Enable=1), the cores interrupts are driven by the IC. The nIRQ line no longer gets connected to the core directly, but becomes just another interrupt source for the IC (a PPI to be precise, with ID 31).
To take an interrupt connected via the IRQS signal you must enable and configure the IC. From your earlier post, you seem to programming all the right registers. Question is what are you programming them to? You could, for example, be enabling ID31 (the nIRQ ID) but not ID32 (the IRQS[0] ID).
On your question about vectors.... No, a Cortex-A9 core has only one IRQ vector.
* Remembering that nIRQ is active low. So to "assert" you actually take the signal low.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 12 years ago
I've only skimmed through the code, but I spotted one thing you might want to look into.
You are writing 0x1F into the CPU Interface Control Register (ICCICR), looking at the GIC spec...
[3] = FIQEn
Setting this bit means that "secure" interrupts are delivered as FIQ exceptions - not IRQs. Earlier in the code you zeroed the Interrupt Security (ICDISR), making all your interrupts secure. So they're all going to be delivered as FIQs.
Have you cleared the CPSR.F bit?
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 12 years ago
The IC in the Cortex-A9 MPCore is GICv1.
Although the GICv2 specification document notes the differences between v1 and v2.
Cancel
Vote up
0
Vote down
Cancel
