Flat memory model
On 32-bit and 64-bit cortex, can we have flat memory management (physical address == virtual address) to remove the cost of a page walk, while not losing on performance (keeping instruction and data caches active)?
Or at least, during the page fault interrupt, may we designate the address to fetch the page from (simple calculation + 1 memory access instead of multiple memory access), avoiding the page table walk?
I am trying to find a way to cancel the need for that slow operation.
  • Interesting question.
    So, with the MMU disabled you get the flat mapping for free.  The downside is that data memory becomes non-cacheable.  (I guess on the cores with virtualization you could use the default cachability upgrade (HCR_EL2.DC) but without stage 2 translation'real' device memory might become unsafe.)
    The only real option is to enable the MMU and flat-map the memory using appropriate memory types.  You can never totally avoid table walks but if you can structure your tables so that mapping are in the TLBs you can reduce them.  This can be done by mapping memory using larger page sizes, which is also easier to do for flat mapped memory layouts.
  • I would suggest to use a page table with super-sections and touch every 16MB area once to force a table walk. After this the translation uses the TLBs (there should be enough) and no more table walk will happen. (Ooops, Peter did suggest the same).
  • Thanks Peter,
    Large pages seem to be the way to go. In case we know how we mapped our memory (baremetal here), isn't it possible to disable the automatic page walk and directly feed the right address to the system in the exception handler?
    I guess it is not possible but that would be very useful.
    According to your feedback I will accept your answer :)
    Thanks  a lot
  • PowerPC CPUs allow to write TLB entries directly. A nice feature.
