about tail chaning of Cortex-M0
Hello.
I'm studying about the tail chaining of Cortex-M0.
Is it same as Cortex-M3 or M4?
Best regards.
  • Hi shimochan and welcome to the Community!
    I have moved your question to ARM Processors where I hope you will get your answer.
  • Hi,
    have you referred to the https://community.arm.com/docs/DOC-2607 ?
    It would be very helpful.
    I think the mechanism of Cortex-M0's tail chainning is the same as Cortex-M4's.
    The difference of the interrupt latencies would come from the differences of the internal bus architecture.
    Cortex-M3/M4 has two AHB Lite buses for instructions and data, and instructions and data can be accessed simultaneously.
    However Cortex-M0 has only one AHB Lite bus and a confliction between instruction and data accesses would cause extra latencies.
    Best regards,
    Yasuhiko Koumoto.
  • Hi, yasuhiko.
    Thank you for your reply.
    I read the page you mentioned once, but I was not ble able not to understand very well.
    I’m not familiar with micro controllers, especially about the data bus.
    I will keep trying to understand deeply what is written on that page.
    Thank you again.
    差出人: yasuhikokoumoto
    日時: 2016年4月28日 13:59
    宛先: 下田敏郎
    件名: Re:  - about tail chaning of Cortex-M0
    reply from yasuhikokoumoto in ARM Processors - View the full discussion
  • Hello shimochan,
    do you want to know what is the tail chaining?
    If it is correct, the tail chaining means that preveios context POP and a new context PUSH will be omitted if the CPU detect another interrupt before POPing the contexts.
    As you know one interrupt sequence takes as the following procedure.
    <1> Detect Interrupt
    <2> Push contexts (r0-r3, r12,r14, r15 and xPSR)
    <3> Jump to ISR
    <4> Process ISR
    <5> Pop contexts (r0-r3, r12,r14, r15 and xPSR)
    <6> Return to the interrupted position
    If the next interrupt detects at the <5> or later, the sequence wil be the following.
    <3> Jump to ISR
    <4> Process ISR
    <*> New Interrupt
    <6> Push contexts (r0-r3, r12,r14, r15 and xPSR)
    <7> Jump to ISR
    <8> Process ISR
    <9> Pop contexts (r0-r3, r12,r14, r15 and xPSR)
    <10> Return to the interrupted position
    Here, the contents of <5> and <6>, and the target stack would be the same.
    Therefore. CPU wants to omit the <5> and <6> processes to avoid the extra stack handling. If the next interrupt would come just before <5>, it would be possible.
    This is the tail chaining. After all, the interrupt sequence would become the following.
    <3> Jump to ISR
    <4> Process ISR
    <7> Jump to ISR
    <8> Process ISR
    As the results, 4 data push and 4 data pop (i.e. 8 cycles at the minimum) could be saved.
    Can this help you?
    Best regards,
    Yasuhiko Koumoto.
