ARMv7 Branch Prediction Enable
On "ARM Cortex -A Series Programmer’s Guide" , a piece of code is followed:
@ Invalidate TLB
MCR  p15, 0, r1, c8, c7, 0
@ Branch Prediction Enable
MOV r1, #0
MRC p15, 0, r1, c1, c0, 0     @ Read Control Register configuration data
ORR r1, r1, #(0x1 << 11)     @ Global BP Enable bit
MCR p15, 0, r1, c1, c0, 0     @ Write Control Register configuration data
Does the statement "MOV r1, #0" have any special intention? The value of r1 will be replaced by the next MRC instruction. Whether can the statement "MOV r1, #0" be deleted?
Can anyone help?
Thanks,
Feng
  • Hello,
    I think the "MOV r1, #0" would be for "@ Invalidate TLB".
    Therefore it should be the followings to invalidate TLB.
    MOV r1, #0
    For enabling the Branch Prediction, it would be needless.
    Best regards,
    Yasuhiko Koumoto.
  • Hi Yasuhiko Koumoto,
    I checked <ARM Architecture Reference Manual ARMv7-A and ARMv7-R edition>. There is an item for invalidate TLB.  So it make me more confused for the purpose of "MOV r1, #0"
    Invalidate entire TLB
    The Invalidate entire TLB operations invalidate all unlocked entries in the TLB. The operation ignores the value in
    the register Rt specified by the MCR instruction that performs the operation. Software does not have to write a value
    to the register before issuing the MCR instruction.
  • Hello,
    thank you for your comment and I have just confirmed by the document.
    However, before Cortex-A architecture appeared, <Rt> value which be 'ignored' for MCR instruction should be SBZ (i.e should be zero).
    The restriction had been relaxed at Cortex-A.
    Now I think 'MOV r1,#0' would be meaningless.
    Otherwise it might be the compiler's convenience.
    By using a GCC, the following source code as
    main()
      int r;
      asm volatile ("MCR  p15, 0, %0, c8, c7, 0" : "=r" (r) : "0" (r));
    generates
    main:
            mov    r3, #0
          MCR  p15, 0, r3, c8, c7, 0
    although the variable is not initialised.
    Best regards,
    Yasuhiko Koumoto.
  • Hello,
    Thanks!!
    I double checked the old ARM document, compiled your code and got the same results as yours. Thank you!
    Best regards,
    Wang Feng
