There is a statement 'For wrapping burst, the length of the burst must be 2,4,8 or 16 transfers.' in AXI Addressing option.
I cannot understand that why must be 2,4,8 or 16 transfers? Is there some design issue?
Hope someone can help,thank you!!
Best Regards,
Evelyn
It's a specification, it's telling you what you are and are not allowed to do, so yes it's a restriction in the specification.
The reason is that you need fewer bits in the bus control signalling, and hence less area and power. It allows encoding burst length as the value (log2(N) - 1), which is a 2 bit field, rather than needing an arbitrary value between 0 and 16 which would be a 4 bit field.
HTH,
Pete
Dear Pete,
Thank you for your reply,
I still confused about the bit field can be reduced you mentioned, since AxLen[3:0] is defined as fixed 4 bit field.
Moreover, is it true that the restriction of wrapping burst length has no relationship with the behavior of wrapping?
Thank you for your help,
Hmm, good point. In general power of two fields are easier to handle in the hardware, so this is still a somewhat pragmatic simplification for most uses, but it does indeed look like my idea above wasn't correct at least at the interface level (an AXI implementation which only handled wrap bursts could use a smaller internal bus, even if the interface expected 4 bits, if it knew that that this constraint was always true). Sorry for the confusion.
IIRC you wrap around based on the natural size of the burst (e.g. a 64 byte burst will wrap on a naturally aligned 64 byte boundary in the middle of the burst, a 32 byte burst will wrap on a 32 byte naturally aligned boundary). However, I'm not 100% sure if this is a limitation of the protocol specification, or just the implementations I have seen.
