Hi Community!
■ Issue DescriptionErrors occur in the burst waveform when accessing external SRAM. The test conditions are as follows:
- MMU enabled
- Data cache disabled
- Page table of the external SRAM area set as cacheable (== write-back/read-write/allocate)
■ InquiryI'm inquiring whether it is permissible to access cacheable areas (== write-back/read-write/allocate) with the data cache disabled.
If anyone could help regarding this , then it would solve a long standing problem for me.
Regards
daehyunyoon said:I'm inquiring whether it is permissible to access cacheable areas (== write-back/read-write/allocate) with the data cache disabled.
By data cache disabled, do you meant that SCTLR_ELx.C is cleared to 0?
If so, yes - it is legal to access regions marked as cache-able in the MMU translation tables with C=0. In the Arm ARM (K.a) you want section D7.5.5 "Enabling and disabling the caching of memory accesses". That says that if you set SCTLR_ELx.C to 0 then the all stage 1 translations will come out as data non-cacheable (so, effectively overriding what you put in the tables).
From the software side you have to be careful to avoid accessing the location as both cacheable and non-cacheable. That can lead to some interest cache coherency problems.
I'm afraid this answer probably doesn't help much in understanding the error in your waveforms, sorry.
The CPU is able to access regions marked as cacheable when data cache is off, I measured that CPU speed would be 20X slower with data cache off.
