Hello Folks,I have a question about not being able to change the GIC memory map in the baremetal development environment.
■ QuestionsI am implementing interrupt processing in a bare metal development environment. If the GIC is placed in the default memory map of the sample project stored in the DS-5 installation directory, interrupts work normally, but if the memory map is changed, the program hangs. Could you please tell me how to fix it?The bare metal development environment uses startup_Cortex-A55_Cortex-A75 which is stored in the installation directory of DS-5 v5.29.3.*Since VirtualPrototyping is used for the target device, it is easy to change the memory map of the circuit.
■Details: What I researchedSince it was necessary to change the physical address size to 1TB (40bits), it was necessary to change the MMU setting, but startup_Cortex-A55_Cortex-A75 (DS-5 v5.29.3.) contains the MMU setting code. I had to code it myself because I didn't have it. When stepping in instruction step mode, the operation becomes strange immediately after writing the set value to the TCR_EL1 register, so I think there is a high possibility that the MMU setting is incorrect. However, I know that the MMU/MPU view of DS-5 or Arm DS cannot be used with the debugger connection method I am currently using.
MMU/MPU view/Commands view cannot be used with DS-5. - Arm Development Studio forum - Support forums - Arm Community
Immediately after writing the set value to the TCR_EL1 register, it seems that the connection with the debugger has been cut off. I don't see any disassembled code, and the general register values say "Error: Target not available". Therefore, it is not known whether an exception interrupt has occurred.
■ Details: How to change the memory mapThe memory map of the GIC has only changed from the default 0x2f000000 in startup_Cortex-A55_Cortex-A75 (DS-5 v5.29.3.) to 0x52800000, which is the target device specification. Specifically, in the scatter file (scatter.scat), the loading destinations of the GICv3 distributor and GICv3 redistributors are changed as follows. I understand that it is possible to change the memory map of GIC only with this change.
; ; GICv3 distributor ; ;GICD 0x2f000000 UNINIT 0x8000 GICD 0x52800000 UNINIT 0x8000 { GICv3_gicd.o (.bss.distributor) } ; ; GICv3 redistributors ; 128KB for each redistributor in the system ; ;GICR 0x2f100000 UNINIT 0x80000 GICR 0x52900000 UNINIT 0x80000 { GICv3_gicr.o (.bss.redistributor) }
■ Details: MMU settingsThe boot code uses startup_Cortex-A55_Cortex-A75 (DS-5 v5.29.3.) as it is. In addition, the sources that I changed the setting by myself are as follows.
#include "mmu.h" #pragma asm extern uint64_t Image$$TTB0_L2_PERIPH$$ZI$$Base; void mmu_init(void) { uint64_t r; uint64_t i; unsigned long* BaseAddress = &Image$$TTB0_L2_PERIPH$$ZI$$Base; printf("MMU table setting\n"); for(i=0;i<508;i++){ mem_write((unsigned long)BaseAddress + 0x00 + 0x20*i ,0x00000F25 + 0x100000000*i); mem_write((unsigned long)BaseAddress + 0x08 + 0x20*i ,0x40000F25 + 0x100000000*i); mem_write((unsigned long)BaseAddress + 0x10 + 0x20*i ,0x80000F25 + 0x100000000*i); mem_write((unsigned long)BaseAddress + 0x18 + 0x20*i ,0xC0000F25 + 0x100000000*i); } asm volatile ("isb"); printf("TCR_EL setting\n"); r = (0b00LL << 37) | (0b010LL << 32) | (0b00LL << 30) | (0b00LL << 28) | (0b00LL << 26) | (0b00LL << 24) | (0b1LL << 23) | (00LL << 16) | (0b00LL << 14) | (0b10LL << 12) | (0b01LL << 10) | (0b01LL << 8) | (0b0LL << 7) | (24LL << 0); asm volatile ("msr TCR_EL1, %0" : : "r" (r)); asm volatile ("isb") ; }
Thank you for reading. As we have learned from continuous research, we will expand the information. Does anyone have information that will lead to a solution?
The method of changing the GIC memory map itself in the bare metal development environment seems to be correct. This is because it works normally depending on the destination address.
When GIC is placed in the following area, it works normally.0x00000000~0x3FFFFFFF
"If GIC is placed in the following area, it will not work properly.*In the ASIC you want to simulate by VirtualPrototyping, it is necessary to place a GIC in the following area."0x40000000~0xFFFFFFFF
For reference, the result of objdumping ELF is below.
sample_A5x.axf: file format elf64-little Sections: Idx Name Size VMA LMA File off Algn 0 EXEC 00004e28 0000000080000000 0000000080000000 00001000 2**11 CONTENTS, ALLOC, LOAD, READONLY, CODE 1 EXEC 00000020 0000000080004e28 0000000080004e28 00005e28 2**3 CONTENTS, ALLOC, LOAD, DATA 2 EXEC 000009f8 0000000080004e48 0000000080004e48 00005e48 2**3 ALLOC 3 ARM_LIB_HEAP 000a0000 0000000080005840 0000000080005840 00005e80 2**0 ALLOC 4 ARM_LIB_STACK 00020000 00000000800a5840 00000000800a5840 00005e80 2**0 ALLOC 5 EL3_STACKS 00008000 00000000800c5840 00000000800c5840 00005e80 2**0 ALLOC 6 TTB0_L1 00001000 00000000800ce000 00000000800ce000 00006000 2**0 ALLOC 7 TTB0_L2_RAM 00001000 00000000800cf000 00000000800cf000 00006000 2**0 ALLOC 8 TTB0_L2_PRIVATE 00001000 00000000800d0000 00000000800d0000 00006000 2**0 ALLOC 9 TTB0_L2_PERIPH 00001000 00000000800d1000 00000000800d1000 00006000 2**0 ALLOC 10 TOP_OF_RAM 00000004 00000000800d2000 00000000800d2000 00006000 2**0 ALLOC 11 CS3_PERIPHERALS 00090000 000000001c000000 000000001c000000 00006000 2**0 ALLOC 12 GICD 00008000 0000000052800000 0000000052800000 00006000 2**3 ALLOC 13 GICR 00040000 0000000052900000 0000000052900000 00006000 2**3 ALLOC 14 .debug_abbrev 0000082e 0000000000000000 0000000000000000 00006000 2**0 CONTENTS, READONLY, DEBUGGING 15 .debug_aranges 00000120 0000000000000000 0000000000000000 0000682e 2**0 CONTENTS, READONLY, DEBUGGING 16 .debug_frame 00002970 0000000000000000 0000000000000000 0000694e 2**0 CONTENTS, READONLY, DEBUGGING 17 .debug_info 0000252b 0000000000000000 0000000000000000 000092be 2**0 CONTENTS, READONLY, DEBUGGING 18 .debug_line 000012a3 0000000000000000 0000000000000000 0000b7e9 2**0 CONTENTS, READONLY, DEBUGGING 19 .debug_loc 00001132 0000000000000000 0000000000000000 0000ca8c 2**0 CONTENTS, READONLY, DEBUGGING 20 .debug_pubnames 00000510 0000000000000000 0000000000000000 0000dbbe 2**0 CONTENTS, READONLY, DEBUGGING 21 .debug_pubtypes 000003e5 0000000000000000 0000000000000000 0000e0ce 2**0 CONTENTS, READONLY, DEBUGGING 22 .debug_str 0000129d 0000000000000000 0000000000000000 0000e4b3 2**0 CONTENTS, READONLY, DEBUGGING 23 .debug_ranges 00000470 0000000000000000 0000000000000000 0000f750 2**0 CONTENTS, READONLY, DEBUGGING 24 .comment 0000037c 0000000000000000 0000000000000000 0000fbc0 2**0 CONTENTS, READONLY
I'm closing this issue as I solved it myself.
After reviewing the MMU settings, it now works normally. thank you for your help.
Thank you for coming back to share the solution you found.
