memcpy on cortex-m7 causes unaligned usage fault
I am migrating my application FW written in C from original target architecture of  cortex-M4 to M7.
A piece of code that works on M4 now triggers an unaligned usage fault on M7, which does memcpy from peripherals region (BKPSRAM in the MCU) to the SRAM1.
The problem I am facing is rather intriguing...the fault would be triggered if the pointer of the destination memory is ODD, no problem if it is EVEN and no matter if it is aligned, and even if the pointer is ODD, there is no fault if the size of the data does not exceed 4 bytes.
The instruction that causes the fault is a LDR, which should support unaligned memory transfer.
Any idea is highly welcomed!
