when reading ARM® System Memory Management Unit Architecture Specification, I noticed that there is a saying in about chapter 5, the last section named <cache maintenance operations>.
In SMMUv2, client devices might perform cache maintenance operations on data and instruction caches, such as evicting data to memory.
Does this mean that SMMU are able to issue some cache coherency transactions to affect caches in ARM core platforms, through CCI for example?
If yes, how?
If no, what does it mean?
Another question is about the address translation in ARM cores platforms, will they go through SMMU too, or use their own MMUs?
A client device (the master connected to the SMMU) might generate broadcast cache operations, which would then pass through the SMMU. Assuming that you had a cache coherent interconnect with DVM, these might then affect the processor. Depending on how the shareability domains were set up, and the details of the transaction.
The SMMU can also directly generate DVM requests, if software writes to one of the TLB operation registers (see section 5.4 of the SMMUv2 spec).
Thanks for your reply, and that indeed helps.
I'm still wondering about the TTB that SMMU use to translate address, as we know , several masters can be connected to the SMMU, so do they share one TTB or own one for each?
Not sure what you mean by TTB. Did you mean TBU (Translatione Buffer Unit)?
Sorry for your confusion, here I mean translation table.
Do they share one translation table or not ?
Maybe.
The SMMU can hold multiple Contexts. A context is made up of a set of translation tables, and the associated register settings.
If you have multiple masters connected to a SMMU, they could all be using the same context (and therefore the same tables). Or, they could all be using different contexts. It all depends on what they are being used for.
Which context is used is based on the StreamID. Often all the accesses from a given master will use the same StreamID. However, it's also possible that one master might use multiple StreamIDs. In which case all those StreamIDs could map to the same context, or each map to different contexts. For example, a DMA controller might support multiple concurrent jobs. You might want each job to use a different context.
Thanks a lot for your helpful explanation!
[Jerry] Usually, cache coherency transactions are issueed by bus master, usually cores. And core can issue TLB either by TLB maitainace instructions or by SMMU register access.
[Jerry] Anybody can help, please?
I can't think of a reason to connect an A class processor via a SMMU. As you said, an A class processor has it's own MMU so it's not typically necessary. That said, I don't think there would be anything to stop you doing it.
You might connect something like a M class processor via a SMMU. For example, to allow the M class processor to access addresses greater than 32-bit.
Thanks for your reply, I am less confused now.
