Setting up IRQ in ARM
Hi everyone
I am new to ARM and really wanted to learn about various aspects of ARM Programming .
I have basic understanding of x86 Assembly.
So,what Specifically I wanted to know is what happens when an external device triggers an interrupt .
Let me put my basic understanding on the same, which I learnt in last few days
Offset Handler
00 Reset
04 Undefined Instruction
08 Supervisor Call (SVC)
0C Prefetch Abort
10 Data Abort
14 (Reserved)
18 Interrupt (IRQ)
1C Fast Interrupt (FIQ)
Whenever Interrupt comes instruction at address 18 is executed
So is it true that it is first instruction executed when interrupts comes??
Or as I read somewhere whenever interrupts comes first it moves from user mode to IRQ mode and cpsr is copied to spsr_IRQ but it happen without an instruction .
After that current instruction is replaced with a blx 0x18
How and where we do need to set the stack for different mode e.g for IRQ mode and Supervisior mode??
In the brancged code
IRQ_HANDLER:
SUB lr, lr, #4
STMFD !sp {r14}
bl IRQ_handler_to_specific_device ;it will branch to actuall hander code.
LDMFD r13!,{r14}
mov pc, r14
Is it all We need to do for setting up Basic IRQ handling ?
Also,how PIC/CPU comes to know that interrupt is coming from which device?
Amit Singh Tomar.
"ARM is taking over the world"
  • Getting interrupts right on ARM can be a little fiddly - you have to get quite a lot of things right, and do them in the correct order. I would highly recommend the ARM System Developers Guide as it walks through a lot of the OS-like behaviors.
    http://books.google.co.uk/books/about/ARM_System_Developer_s_Guide.html?id=vdk4ZGRqMskC&redir_esc=y
    Also note that the Cortex-M series does things totally differently with a simpler interrupt model and much more of the low level interrupt handling done in hardware.
    To answer your questions ...
    Yes.
    Stacks need to be setup when your OS boots, before the first interrupt happens.
    No. Most of the ARM registers are shared with the context of the application which was running when the system was interrupted, so you need to stack off these registers before the main part of the interrupt handler runs, or you may corrupt state. You also have to restore them at the end before you return.
    You also need a special return instruction which will restore the SPSR into the CPSR - you can't just "mov pc, r14". This link may help, although it only gives the bare essentials:
    ARM Compiler toolchain Developing Software for ARM Processors: Return from an exception handler
    Depends on implementation. Some devices provide a vector-based interrupt handler so the device can jump directly to the correct handler, others require the interrupt handler to query the interrupt controller to find out which line was activated.
    HTH,
    Pete
  • Hi Amit,
    A couple of other things worth noting on top of what Pete has said if you want your IRQ_handler_to_specific_device to be written in C:
    1.You'd need to think about pushing r0-r3 and r12 as these may be corrupted by the called function (based on the AAPCS) - Pete alluded to this
    2. You'll need to make sure the stack is 8-byte aligned prior to the BL
    Also note, by default, the IRQ is non-reentrant. This means if you have multiple interrupt sources you'll need to poll them to find the actual source (ineffienent).
    You can play games to support reentrant IRQs by swapping to the SVC mode before reenabling the I-bit but this gets even more messy.
    Alternatively your device may have (probably has) an external interrupt controller or vectored interrupt controller to help support and prioritise multiple IRQs. Most ARMv7-A cores will probably use the ARM GIC for interrupt control which handles multiple interrupt sources and maps them onto the IRQ (especially in multi-core where you might want to select which external int is mapped to which cores IRQ).
  • Thanks Niall for your reply
    But I really can't think why r0-r3 and r12 need to be pushed and where/when it need to pushed.
    Also,would you please provde any link where a simple IRQ handler is written in assembly.
    I really not sure what exact has to be there to handle a irq interrupt
  • Hi Tomar,
    You've had some great replies so far. Hope they've been useful.
    You need to push r0-r3,r12 because the AAPCS (Procedure Call Standard for the ARM Architecture) says that a called function may corrupt these registers. Since an interrupt handler is not allowed to corrupt any registers, if you call another function in your handler, you need to preserve these registers before doing so.
    For details of how to write an interrupt handler in assembler, have a look at this section of the compiler documentation ARM Information Center
    Hope this helps
    Chris
  • Absolute minimum handler:
    IRQ_handler
         SUB       lr, lr, #4       ; modify LR
         SRSFD     #0x12!           ; store SPSR and LR to IRQ mode stack
        PUSH      {r0-r3, r12}     ; store AAPCS registers on to the IRQ mode stack
         BL        IRQ_handler_to_specific_device
         POP       {r0-r3, r12}     ; restore registers
         RFEFD     sp!              ; and return from the exception using pre-modified LR
    * Note this does not handle stack alignment
  • Yes, Tomar, you could use those instructions to manage the stack alignment. You would need to remember to "undo" any change you have made to the stack pointer before returning from the handler, though. You can do this by simply adding back the value in r4.
    In the SRSFD instruction, 0x12 is the mode number of the IRQ mode (i.e. the value in the mode field of CPSR which specifies IRQ mode) so this is what specifies use of the IRQ stack. You are right that there is no real need to save SPSR if you are not expecting any further interrupts. So you could just push LR at this point. I think we would say, though, that SRS/RFE is a more modern pair of instructions these days!
  • Thanks Chris, your comments are indeed quite useful !!!
  • Absoultey thanks to you Niall.
    This is exactly what I am looking for
    I guess I can manage Stack alignment using below instructions
    and r4, sp, #4
    sub sp, sp, r4
    Only one doubt I do want to get cleared
    SRSFD #0x12!
    Is this Instruction is really required?
    Since we are not expecting any other interrupts here and it just a simple IRQ handler(not the nested one)
    So,why we do require to save the SPSR here.
    Also,I don't know how SRSED works, I mean how it pushes the SRSR and LR to IRQ mode stack
    Is #012 is base address of IRQ mode stack?
