SoC Design and Simulation blog Standard Cell Benchmarking: Avoiding Five Common Pitfalls
  • benchmark
  • standard_cells
  • libraries
  • logic
  • wire
  • power_networks
  • artisan
  • evaluation
  • sc
  • Library
Leah Schuth
Leah Schuth
October 28, 2013
Less than one minute read time.
Proper evaluation of standard cell libraries should lead you to select standard cells that will optimize power, performance and area for your design. This presentation reviews general evaluation practices and highlights potential pitfalls which could lead to erroneous results. Topics include an overview of an optimized power network, alignment to the library architecture, "don't use" cell lists, edge rates and wire lengths.
ARM_Artisan_SC_Benchmarking.pdf
  • Leah Schuth
    Leah Schuth over 11 years ago
    To any physical IP users out there: I'm interested to know about how much time is typically allocated for logic benchmarking. Any time frames?
  • Leah Schuth
    I made just a few changes to this document to address libraries using either M1 only power rails or M2 (with or without M1) power rails.
  • John Heinlein
    John Heinlein over 12 years ago
    Thanks, Leah! It's surprisingly difficult to benchmark correctly and there are many ways you can get an incorrect assessment.  Leah's description here shows a number of key things to watch for as you're analyzing Standard Cell options.
    Tony Nip
    Tony Nip
    • June 30, 2025
    Vincent Yang
    Vincent Yang
    • June 5, 2024
  • Introduction to AMBA Viz
    Tony Nip
    Tony Nip
    • May 31, 2024
