Hello
I am new to AMBA and I am writing code AHB slave in one of my project, I have read specs.
My question is Is there any specific condition for slave when it gives HREADY low?
I am confused with HREADY signal that it is provided by the slave but at which time and in which condition HREADY becomes low?
Thanks in advance.
Hi ajoo,
HREADY is used by a slave to add wait states to the data phase of an access, so whenever it needs more time to complete a transfer request. The reasons why that slave might need to add a wait state depend on the slave design.
For example if the slave is a bridge to an APB slave, the APB access takes a minimum of 2 cycles to complete, so at the end of 2 cycles the AHB slave "bridge" can then drive HREADY high to signal the APB access has completed, but it needed to hold HREADY low for the 2 cycles during which the APB access was occuring (it needed to stall the master).
Hope that helps,
JD
