Hi Team,
We are facing issue in reboot path. When we trigger the "reboot -f" command from host. The setup is failed at BL1 stage.
It is failing at In BL1 enable_mmu_direct_el3(flags) function. We have debugged the code and it is failing exactly at assembly instruction "isb" in enable_mmu.s file. It's triggered exception due to failed to read memory address.The exception is SynchronousExceptionSPx .
We expected cold reboot should happen in FVP RDV2. But we are stuck at this point. Please help us to proceed further.
Thanks,
Srinivas M
Hi ,
Can I get any inputs? Please help us out.
Invoking "reboot" with the "-f" option is to bypass all the shutdown steps meaning that you could corrupt your file system and potentially lose all your data so it doesn't seem to be appropriate to cold reboot with "-f". Try to invoke "reboot" without "-f".
