I have a NIC-400 configuration that has many interfaces. Every time I add/remove an interface I need to go into uArchitecture Editor and add the Timing Closure register slices manually to each and every interface. This is a tedious and error-prone process. Is there a way for me to use the Ruby API so I can automate this process? I didn't see any Timing Closure options in the Configured Component API documentation.
Or I would appreciate any advice on how to make this Timing Closure process easier. Thanks.
