How to enable PCI & AHCI and mount a SATA disk on Armv-A Base RevC FVP?
Hi, I want to create an external SATA storage disk and mount it to the Armv-A RevC FVP version 11.20 (with Linaro OpenEmbedded file system).
I followed the instructions in the Run the Arm Platforms deliverables on an FVP, and leverage linaro's workspace (git.linaro.org/.../) to setup the Openembedded file system and linux.
Now I want to mount an extra disk image to the system to serve as the storage.
I tried the following steps:
1. Create a disk of 10 GB: dd if=/dev/zero of=/path/to/1.satadisk bs=1G count=10
2. Add the path to the FVP launch options: "-C pci.ahci_pci.ahci.image_path=/path/to/1.satadisk"
However, after I started the FVP, it seems that this disk isn't mounted to the system. The output of lspci is empty, and the output of lsblk only shows two virtioblocks.
$ lsblk
vda
 | -vda2
 `-vda1
What steps did I miss? Thanks!
0
