Dear All,
In FlashLoader_ASM();, There are main 2 thing operations.
1. Get initial MSP value
2. Get initial PC valie.
in gpio_tests example,
HADDR[11:0] has got 000---------->004--------->20C--------->2C8--------->2C4--------->2C8--------->2CC
HRDATA[31:0] has got --------------->20000208->010002c5->00000000->00000000->47804806->47004806
it meant that MSP is 20000208 and PC 010002c5, and PC will indicate that it jumps to reset_handler and executing the instructions I think.
From here, But I got some questions.
1. Why does not bootloader.HADDR increase at the some specific range 004--------->20C not 004--------->008?
2. Similar question of 1, bootloader.HADDR go with 2C8--------->2C4--------->2C8--------->2CC, but my expectation was that 2C8--------->2CC--------->2D0--------->2D4 not 2C8--------->2C4--------->2C8--------->2CC. Why does not HADDR increase sequentially?
3. I found some miss matched value in bootloader.HRDATA[31:0] with bootloader.hex(boot_hex.txt) But I can't understand why it is miss matched between HRDATA and bootloader.hex image file?
It is hard to answer without full information, but...
1) The first two reads are from 0x0 and 0x4, and are the values of the SP and PC... see the vector table definition:https://developer.arm.com/documentation/dui0662/b/The-Cortex-M0--Processor/Exception-model/Vector-table
The PC is then set as per the table.
2) It seems likely that the code it has jumped to is a loop... can you see the instructions of the code that you have jumped to?
