The rate limit setting does not seem to work on the Cortex-M7 FVP MPS2. My code seems to run way faster than wall clock time, and the rate limit setting makes no difference to the speed it runs. Has anyone seen this issue?
I am not familiar with this setting, could you be more specific on which option you are using?
The Rate Limit checkbox on the display. It attempts to bring the performance index to 1 so that the simulation runs at wall clock speed. However the problem is that the performance index does not work so causes the rate limit to fail. ARM support are aware of the problem and it should be fixed in the next release.
