Can I change the path to MSBuild in System Canvas?
Hello, All,
I recently installed Fast Models (Windows 10). I am trying to run the 'hello world' project from GitHub (github.com/.../hello-world_fast-models) for the Cortex-M3. When I try to build it in System Canvas, I receive a log output that ends with the following lines:
<begin log content>
Launching MSBUILD ("C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\MSBuild\15.0\Bin\amd64\MSBuild.exe"  /nologo .\Win64-Debug-VC2017\m0_cadi_system_Win64-Debug-VC2017.vcxproj /p:Configuration=Debug  /p:Platform=x64 )
Build process failed!
Information (Model Build) Model Build process terminated with error.
<end log content>
In the log, the path to MSBuild.exe passes through the "Professional" folder. But in the installation path on my machine, that folder is replaced with "Enterprise".
I tried closing System Canvas and using the following at the Windows command prompt:
"C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Auxiliary\Build\vcvarsall.bat" amd64
But I got the same log readout in System Canvas. Is there a way that I can change the path that System Canvas uses to find MSBuild? Or maybe that's not actually my problem?
Thanks in advance for any help!
  • the vcvarsall.bat script should set the path correctly.  please try: call "C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Auxiliary\Build\vcvarsall.bat" amd64 from the command line.  Note that we do not officially support the Enterprise version of VS 2017.  We only validate the tools with VS 2017 Professional.  We expect that it will work OK, but can't offer support if it doesn't.
  • Thanks for your reply! As you suggested, I tried
    from the command line and then opened System Canvas. I got the same generic error. But I found that when I opened System Canvas from the Windows command line using
    sgcanvas
    instead of from the Windows Start menu, it gives me more specific error info in the log. So I'm down that rabbit trail now. I'll start a new thread if I can't get past it. Thanks again!
  • the location of MSBuild should be getting picked up from the PATH environment variable.   Can you check what that is set to?   Also - from the command line - a "where MSBuild" will tell you what version is being picked up.
    you can get more information from simgen by adding "-v on" or "--verbose on" to the command line arguments.
    if you are still getting problems, please send me the log with the error messages.
  • Thanks again for your reply. I had the path to the compiler set correctly. Once I could see the actual error messages, I realized I needed to have Visual Studio reinstalled with MFC and ATL support included, as well have the Universal CRT SDK installed. That allowed me to build the 'hello world' project.
    Thanks again for your replies!
