Hello, I am trying to run a "hello world" program with C/C++ standard library support on Morello board (hardware), using Arm Development Studio Morello edition.
I previously followed the standalone-baremetal-readme.rst guide which worked well (following the advice from this topic), but it did not allow to use functions like "printf".
I tried to use examples from:
https://git.morello-project.org/morello/llvm-project-releases/-/tree/morello/baremetal-release-1.6?ref_type=heads
I ran make and the "make-bm-image.sh" with "-e" flag to produce "howdy-purecap-bm-image.elf" and "howdy-morello-bm-image.elf" (in the "make-bm-image.sh" script I added a line to preserve a copy of the .elf file), then I loaded these in the development studio.
It appears that the program goes to address 0x200 after executing the "MRS" instruction.
Does anyone know why that happens?
Also, in the standalone-baremetal-readme.rst guide it was necessary to specify UART address (0x2A400000) in the program, is it correct to assume that examples from baremetal-release-1.6 branch of llvm-project-releases will use that address (without the need to specify it anywhere in the program) and the printf/cout messages will appear in the AP com port of Morello hardware board? Or is it necessary to do some adjustments to achieve that?
In attempt to run a baremetal program using C standard library function on hardware, I also tried using GNU Morello toolchain (arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf.tar.xz),
I am not familiar with integrating standard library to embedded systems so I tried to follow this tutorial:
https://www.youtube.com/watch?v=AzYC5hO2uJk
I used the following makefile, linker script and "syscalls.c" trying to compile a "hello_world" program (I uploaded all files to Github):
- Makefile
- linker_script.ld
- hello_world.c
- syscalls.c (with modified _read and _write functions to use 0x2a400000 address, and modified _sbrk to use the HEAP_START symbol from the linker script, I verified that this kind of setup worked well using riscv-unknown-elf toolchain before)
During compilation I got error about undefined functions like this:
michal@ubuntu22-04:~/morello/standalone_build/helloworld$ make aarch64-none-elf-gcc -march=morello+c64 -mabi=purecap -static -fvisibility=hidden -I../include -g -o hello_world hello_world.o ./syscalls.o -T linker_script.ld /home/michal/arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf/bin/../lib/gcc/aarch64-none-elf/10.1.0/../../../../aarch64-none-elf/bin/ld: /home/michal/arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf/bin/../lib/gcc/aarch64-none-elf/10.1.0/../../../../aarch64-none-elf/lib/purecap/c64/crt0.o: in function `.pure': /data/jenkins/workspace/GNU-toolchain/morello-trunk/src/newlib-cygwin/libgloss/aarch64/crt0.S:243: undefined reference to `__init_global_caps' /data/jenkins/workspace/GNU-toolchain/morello-trunk/src/newlib-cygwin/libgloss/aarch64/crt0.S:243:(.text+0x184): relocation truncated to fit: R_MORELLO_CALL26 against undefined symbol `__init_global_caps' /home/michal/arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf/bin/../lib/gcc/aarch64-none-elf/10.1.0/../../../../aarch64-none-elf/bin/ld: /data/jenkins/workspace/GNU-toolchain/morello-trunk/src/newlib-cygwin/libgloss/aarch64/crt0.S:244: undefined reference to `__processRelocs' /data/jenkins/workspace/GNU-toolchain/morello-trunk/src/newlib-cygwin/libgloss/aarch64/crt0.S:244:(.text+0x188): relocation truncated to fit: R_MORELLO_CALL26 against undefined symbol `__processRelocs' /home/michal/arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf/bin/../lib/gcc/aarch64-none-elf/10.1.0/../../../../aarch64-none-elf/bin/ld: hello_world.o(.rela.got+0xf0): warning: relocation R_MORELLO_ADR_GOT_PAGE against symbol 'SBSS_START' in section without permission flags '.sbss'. Assuming Read-Write. /home/michal/arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf/bin/../lib/gcc/aarch64-none-elf/10.1.0/../../../../aarch64-none-elf/bin/ld: hello_world.o(.rela.got+0x10): warning: relocation R_MORELLO_ADR_GOT_PAGE against symbol 'SBSS_END' in section without permission flags '.sbss'. Assuming Read-Write. collect2: error: ld returned 1 exit status make: *** [Makefile:43: hello_world] Error 1
From what I see, the __init_global_caps and __process_relocs functions are in the following file (assumming that the newlib from link below is the same newlib used in the GNU toolchain):
https://git.morello-project.org/morello/newlib/-/blob/morello/master/libgloss/aarch64/relocs.c
But for some reason the error message says these functions/symbols are undefined.
Hi there,
I'm not familiar with running bare-metal directly on the Morello hardware -- however I can at least help a bit with the GNU toolchain.The `__init_global_caps` and `__processRelocs` functions are indeed in the distributed newlib, however newlib happens to be split in two.The libgloss directory contains bits relevant for specific board support, and are not linked in with `-lc`.The distributed toolchain contains a purecap compiled version of the libgloss parts with the Morello GNU toolchain release, you can link it in with `-lrdimon`.N.b. this `librdimon.a` library also includes an implementation of all the syscalls using semihosting -- though I believe your syscalls.c implementations would get chosen preferentially.
Usually a user would be expected to use one of the `-specs=<something>.specs` arguments provided with the toolchain in order to target a specific bare metal configuration.You can find the available options with `find arm-gnu-toolchain-10.1-morello-alp2-x86_64-aarch64-none-elf/ -name '*.specs'` (look for those in a `purecap` directory).I would guess that one of the pre-packaged set of options would work for you, but can't say I've tried it out to know for certain.My guess would be that `-specs=aem-validation.specs` would be best for you (this includes code to get a board started from EL3 and doesn't provide a default address for text to start at), another option to look into would be `-specs=rdimon.specs` which does not include the startup code for EL3.
Hope that helps you figure things out -- apologies I can't say exactly what would work,Matthew
Hello, thank you very much for help. I tried using aem-validation.specs and rdimon.specs, both fix the compilation error. But the problem with jumping at 0x200 address persists. It seems that the "MRS x0, CPACR_EL1" is executed correctly but after the execution of "MRS x0, CPTR_EL3" it jumps at 0x200.
I have investigated this issue further. What is happening is clear: CPTR_EL3 is an EL3 register, so trying to access it at EL2 will cause an exception. This is because the default baremetal initialisation code is meant for EL3; a similar issue was previously reported, notably:
https://community.arm.com/support-forums/f/morello-forum/52923/baremetal-tfa-payload-built-for-capability-mode-still-in-pstate-a64-on-el2-entry
The good news is that since then, Silviu Baranga added support for booting at EL2 in Newlib:
https://git.morello-project.org/morello/newlib/-/merge_requests/17
As far as I can tell there is however no easy way to make the LLD baremetal driver choose the EL2 boot code instead of EL3, for reference:
https://git.morello-project.org/morello/llvm-project/-/blob/morello/master/clang/lib/Driver/ToolChains/AArch64BareMetal.cpp?ref_type=heads#L255
I think you could work around that by passing -nostdlib to LLD, and then explicitly specify all startup files. With LIB the local path to this directory:
https://git.morello-project.org/morello/llvm-project-releases/-/tree/morello/baremetal-release-1.6/aarch64-none-elf/lib
The flags to pass to LLD would be:
-nostdlib LIB/morello-el2-crt0.o LIB/crti.o LIB/cpu-init/morello-init-el2.o --start-group -lc -lgloss-morello-el2 --end-group -lclang_rt.builtins-aarch64 LIB/crtn.o
Note that I have not actually tested this command line, but hopefully it will work as intended.
Is there some flag for GCC that could be added in order to not use EL3 and use EL2 instead? I tried adding "-D__MORELLO_EL2__" (by looking at the changes from this commit) but it keeps producing "MRS x0, CPTR_EL3".
Does it mean that the compiler itself must be recompiled with that flag?
Caveat of everything I say:I've checked things build with the libraries Kevin mentions, but not checked they run on the board (because I don't have easy access to a board).
I just had a look for those libraries Kevin mentioned in the GCC toolchain distribute. Those libraries are not in the package.One option would be to link to the libraries in the LLVM toolchain (if you have that), but rebuilding just newlib with the required flags isn't too hard and should leave you with a GNU something much easier to use.
You shouldn't have to recompile much of the toolchain -- just these particular libraries.
FWIW I've inlined a session demonstrating how to build newlib starting with the GNU toolchain we distribute.Hopefully the comments should explain what's happening and why.
vshcmd: > # Recommend using a separate untar of the toolchain.vshcmd: > # (Replacing bundled binaries with newly built binaries. I don'tvshcmd: > # know for certain these binaries would work -- though I think it's avshcmd: > # good enough chance to try.)vshcmd: > tar -xaf arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf.tar.xzmorello-distro [14:06:32] $ vshcmd: > # Just to de-mystify this helper function I happen to use.vshcmd: > type newdirnewdir is a functionnewdir () { mkdir -p "$@"; cd "${@: -1}"}morello-distro [14:06:34] $ vshcmd: > newdir rebuild-newlibrebuild-newlib [14:06:36] $ vshcmd: > git clone git.morello-project.org/.../newlib.gitCloning into 'newlib'...<snip>vshcmd: > newdir newlib-buildnewlib-build [14:07:32] $ vshcmd: > PATH="$(pwd)/../../arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf/bin:$PATH" \vshcmd: > CC_FOR_TARGET=aarch64-none-elf-gcc \vshcmd: > CFLAGS="-O1 -g" \vshcmd: > CFLAGS_FOR_TARGET="-ffunction-sections -fdata-sections -O2 -g -DWANT_CHERI_QUALIFIER_MACROS -D__cheri_fromcap=" \vshcmd: > CXXFLAGS_FOR_TARGET="-ffunction-sections -fdata-sections -O2 -g -DWANT_CHERI_QUALIFIER_MACROS -D__cheri_fromcap=" \vshcmd: > ../newlib/configure --disable-newlib-supplied-syscalls \vshcmd: > --enable-newlib-retargetable-locking \vshcmd: > --enable-newlib-reent-check-verify \vshcmd: > --enable-newlib-io-long-long \vshcmd: > --enable-newlib-io-c99-formats \vshcmd: > --enable-newlib-register-fini \vshcmd: > --enable-newlib-mb \vshcmd: > --target=aarch64-none-elf \vshcmd: > --prefix=/ --with-pkgversion=unknown<snip>vshcmd: > # N.b. I happen to build the entirety of newlib.vshcmd: > # I expect that we could get away with only building libgloss, butvshcmd: > # building everything doesn't take too long.vshcmd: > PATH="$(pwd)/../../arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf/bin:$PATH" \vshcmd: > make -j8 all-target-newlib all-target-libgloss<snip>vshcmd: > # One option is to install in a local directory.vshcmd: > PATH="$(pwd)/../../arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf/bin:$PATH" \vshcmd: > make DESTDIR=$(pwd)/../newlib-install \vshcmd: > INSTALL="/usr/bin/install -C" \vshcmd: > install-target-newlib \vshcmd: > install-target-libgloss<snip>vshcmd: > # I believe you would be able to directly use these binaries usingvshcmd: > # `-nostartfiles` to avoid the non-EL2 crt0.o file and then manuallyvshcmd: > # specifying the crti.o, crtbegin.o, and morello-el2-crt0.o file.vshcmd: > # (N.b. don't worry about the warning -- it's not something thatvshcmd: > # should stop things working).vshcmd: > cd ../../vshcmd: > ./arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf/bin/aarch64-none-elf-gcc \vshcmd: > -march=morello+c64 -mabi=purecap -nostartfiles -L rebuild-newlib/newlib-install/aarch64-none-elf/lib/purecap/c64/ \vshcmd: > -Wl,arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf/lib/gcc/aarch64-none-elf/10.1.0/purecap/c64/crti.o,arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf/lib/gcc/aarch64-none-elf/10.1.0/purecap/c64/crtbegin.o,./rebuild-newlib/newlib-install/aarch64-none-elf/lib/purecap/c64/morello-el2-crt0.o,./rebuild-newlib/newlib-install/aarch64-none-elf/lib/purecap/c64/cpu-init/morello-init-el2.o,--start-group,-lc,-lgloss-morello-el2,--end-group,arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf/lib/gcc/aarch64-none-elf/10.1.0/purecap/c64/crtend.o,arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf/lib/gcc/aarch64-none-elf/10.1.0/purecap/c64/crtn.o test.c -o test-direct-altmorello-distro [14:28:06] $ > > <snip>/aarch64-none-elf/bin/ld: rebuild-newlib/newlib-install/aarch64-none-elf/lib/purecap/c64//libgloss-morello-el2.a(morello-el2-uart.o)(.rela.got+0x1c0): warning: relocation R_MORELLO_ADR_GOT_PAGE against symbol '__UART' in section without permission flags '*ABS*'. Assuming Read-Write.morello-distro [14:28:06] $ vshcmd: > # However, it seems like it would be neater to instead install intovshcmd: > # the GCC install directory. Then create a new `specs` file so youvshcmd: > # don't have to always specify the required crt0 startup objectvshcmd: > # files.vshcmd: > cd rebuild-newlib/newlib-build/vshcmd: > PATH="$(pwd)/../../arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf/bin:$PATH" \vshcmd: > make DESTDIR=$(pwd)/../../arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf \vshcmd: > INSTALL="/usr/bin/install -C" \vshcmd: > install-target-newlib \vshcmd: > install-target-libgloss<snip>vshcmd: > cd ../../morello-distro [14:29:51] $ vshcmd: > # Manually defined specs file (i.e. write the below in the relevant file).vshcmd: > # Includes the new crt0.o file and the new morello-init-el2.o file.vshcmd: > cat arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf/aarch64-none-elf/lib/morello-board-el2.specs%rename lib libc*libgloss:-lgloss-morello-el2*startfile:crti.o%s crtbegin.o%s morello-el2-crt0.o%s*lib:cpu-init/morello-init-el2.o%s --start-group %(libc) %(libgloss) --end-groupmorello-distro [14:30:05] $ vshcmd: > ./arm-gnu-toolchain-10.1.morello-alp2-x86_64-aarch64-none-elf/bin/aarch64-none-elf-gcc \vshcmd: > -march=morello+c64 -mabi=purecap -specs=morello-board-el2.specs test.c -o test> <snip>/aarch64-none-elf/bin/ld: <snip>/aarch64-none-elf/lib/purecap/c64/libgloss-morello-el2.a(morello-el2-uart.o)(.rela.got+0x1c0): warning: relocation R_MORELLO_ADR_GOT_PAGE against symbol '__UART' in section without permission flags '*ABS*'. Assuming Read-Write.morello-distro [14:31:11] $
Thank you very much, I would never be able to do that on my own.
I followed the instructions and got the newlib-install ready, I recompiled the program and it looks like it no longer uses the CPTR_EL3.
But I encountered another issue while trying to run the "hello_world" program. The _start function executes succesfully, after that it enters ".pure" function and that's where LDR instruction is never completed, the program jumps to 0xE0002200, then to "curr_sp0_fiq" and the never ending loop because STP instruction from image below is also never completed.
I made this permalink to the Makefile I used:
https://github.com/michalmonday/morello_baremetal/blob/5c17d0600a0ae10549e414f70b3bf86fc58a253e/Makefile
And this permalink to the objdump it produced:
https://github.com/michalmonday/morello_baremetal/blob/5c17d0600a0ae10549e414f70b3bf86fc58a253e/hello_world.dump
I tried running it with and without ".ds" script from this reply about semihosting (because curr_sp0_fiq was mentioned in that thread):
set semihosting heap-base 0 set semihosting heap-limit 0x80800000 set semihosting stack-limit 0x80800000 set semihosting stack-base 0x81000000 set semihosting enabled on
But in both cases the behaviour was the same.
It looks like an exception occurs here:
https://git.morello-project.org/morello/newlib/-/blob/morello/master/libgloss/aarch64/crt0.S#L180
Hard to say why without more information. Have a look at the value of the ESR_EL2 system register just after the exception is taken, feel free to copy it here.
I just tried to do the same thing I did before (using the same hello_world program), and somehow the LDR instruction does not cause exception anymore, no idea why. I am facing another issue, when I step through the program using "F5" (step into), multiple function calls execute and return well. But when I use "F6" (step over), each of the following functions result in jump to "curr_sp0_fiq":
-_cpu_init_hook (the cpu_init_hook seems to have "ret" instruction only in the source code, but in the disassembler it calls _init_vectors and _flat_map, I attached image of it below)
- _init_vectors
- _flat_map
- memset
I didn't test using F6 with any other functions, but every function I tried to step-over resulted in exception.
I tried to use breakpoints to find part of code that potentially cause this exception, but working with breakpoints seems unstable (sometimes running the code until breakpoint worked well, sometimes it crashed the ARM Development studio, sometimes it made program jump at address 0 and required rebooting the board).
In this thread the same behaviour was described (where stepping through code worked, and running it resulted in exception), and the suggested solution was to introduce 2 ISB instructions, but from what I see in the "rebuild-newlib" I used, these 2 ISB instructions are already in the following file:
newlib/libgloss/aarch64/crt0.S
I checked system registers after the program went to "curr_sp0_fiq" (following F6/step-over functions) and the values were always the following:
I'm really not sure what is happening regarding stepping over. A few things I can say though:
It is a tricky issue to debug because pressing F6 to step-over function does not stop the execution, it just makes the code run forever (just like it happens on the image with red arrows), so after pressing the pause button, the state of registers is different from the state of registers when the "curr_sp0_fiq" was invoked for the first time (which makes it difficult to recognize what caused the issue in the first place).
After stepping over the _cpu_init_hook function and pressing the pause button, here's what I can see:(I highlighted some registers with orange because the font is awkward without it and names can't be seen, changing theme didn't help)
If I understand correctly the STP instruction in "write" function makes the program jump to "curr_sp0_fiq". And the STP instruction used C29, C30 and CSP capabilities. CSP appears to have the value 0xFF000000, and because the STP instruction specifies "-32" offset I checked the 0xFEFFFFE0 address contents (no idea if this is helpful in any way):
My previous reply to this message was hidden so it may appear after this one.
I just realized that connecting to "Rainier_SMP_0" or "Rainierx4 Multi-Cluster SMP" (instead of "Rainier_0") causes the LDR instruction (the first instruction of ".pure" function that follows "_start") to jump at 0xE0002000 (and then at "curr_sp0_fiq").
I don't know why but at least it gives the opportunity to view registers values when the issue first happens.
This is the whole code that executes before LDR instruction fails:
After the jump at 0xE0002000, this is the state of registers/memory:
The ESR_EL2 mentions "Capability tag fault", do you know what could be the cause of it? Is it because C0 tag is not equal to 1 for some reason?
Ah that is indeed progress. Your first post suggests some kind of stack overflow, as CSP hits its lower bound. Clearly this is a consequence of something else going wrong, probably related to this strange stepping behaviour.
The second post is a lot more straightforward: the function pointer C0 is null-derived, so BR C0 will cause PCC to become an invalid capability and thus cause an instruction abort right away. Of course the question is why C0 would be null-derived. Assuming the code sequence is correctly executed, this could only happen if DDC itself is null. Could you check the value of DDC_EL2?
It seems to be all zeros:
Right, that'll be your problem. How that came to pass, I have no idea... The first step would be to check if it is valid at the very beginning of the execution. If not, there must be something going wrong with the firmware.
