Hi
I noted from a previous post (7 months ago) that support for linux pure-cap libc++ was not yet available - is this now available? If so please can you advise how to get it?
It appears that the morello aarch64 linux pure-cap toolchain only has the MUSL CRT libraries built for aarch64 purecap, the C++ libs are aarch64 only.
Note that I downloaded the build artefact https://git.morello-project.org/morello/musl-libc/-/jobs/artifacts/morello/master/download?job=build-musl-aarch64 ... perhaps some other artefact now has the needed support?
Pete
Hi there,
I'm not sure this will help your specific use-case, but in case (and anyone else reading):
There is a libstdc++ in the GNU Morello toolchain, which can be found here https://developer.arm.com/downloads/-/arm-gnu-toolchain-for-morello-downloads.(Heads-up the GNU toolchain is alpha quality).
Cheers,
Matthew
Hi Pete,
Thanks for the question! We're working on adding C++ binaries into the LLVM toolchain for Linux and it should become available via the artefact on GitLab that you mentioned in a few weeks time. At first, it is going to be experimental, so any feedback would be greatly appreciated. I'll add a comment here once you can download it from GitLab.
Thanks,Yury
Thanks Matthew for the heads up, I will check out the GNU tools - might be useful for me.
Thanks Yury, that's good to know! Will look out for the update.
Cheers
Hello Pete,
A quick update. We have recently updated one of the scripts that are used to build the toolchain: tools/build-morello.sh. New version have three experimental steps: libunwind, libcxxabi, and libcxx. They allow to build C++ libraries from LLVM for purecap target and link them to purecap Musl. I must warn that they are very experimental at this point only build static versions of these three libraries, but you are welcome to try and see if it works for you. We hope to improve this at some point.
libunwind
libcxxabi
libcxx
Thanks Yury, I'll give that a try asap!
Another quick update: this document should hopefully explain how to use build-morello.sh script: build-morello-clang.rst.
Hi Yury, sorry it took so long but I have now tried out the new C++ support on Linux pure-cap. However I have had problems building example C++ code because the C++ exception table entries are not being built properly. This means any exception thrown in my code gets unhandled. Specifically, I am getting warnings like the following at the link stage, for all symbols:ld.lld: warning: Could not find a real symbol for .gcc_except_table._ZNSt3__113basic_ostreamIcNS_11char_traitsIcEEE5flushEv+0x70 in /llvm-morello-build/musl-bin/lib/libc++.a(ios.instantiations.cpp.o)I presume I am making some silly mistake but I am not sure what? - hope you can help.How I built the toolchainI followed your steps in build-morello-clang.rst however note that:- I did not build clang from source, instead I downloaded the morello llvm-project-release v1.6- I had to define an env var LLVM in order to build the kernel headers (ref __download_kernel_headers() from build_morello.sh) after extracting the tar file- Note I am cross-compiling, but it shouldn't make any difference
How I build example C++ fileIt's pretty much the same way as per the Morello C examples... Compiling:clang++ march=morello+c64 --target=aarch64-linux-musl_purecap --sysroot /path/to/musl-bin -g -c example.cpp -o example.cpp.o
Then linking:
clang -fuse-ld=lld march=morello+c64 --target=aarch64-linux-musl_purecap -nostdlib -L/path/to/musl/bin -lc -lc++ -lc++abi -lunwind <clang_abs_path>/clang_rt.ctbegin.o <clang_abs_path>/clang_rt.ctend.o <clang_abs_path>/libclang_rt.builtins.a <musl_bin>/lib/crt1.o <musl_bin>/lib/crti.o <musl_bin>/lib/crtn.o -Wl,--gc--sections -static -o example.out example.cpp.o
Note that all else seems to work ok apart from exception handling.(Limited testing so far: from C++ stdlib I have used iostream, string, sstream, unordered_map. Also have been using templates (basic), global operator new & delete. Note I am targeting c++14).ThanksPete
Hi Pete and thanks for such a comprehensive report!
The linker warning
is a known issue and you should be able to just ignore it. At some point it should be fixed. You may add -Wl,-warning-limit=1 to your command like to see fewer warnings.
It is totally fine to use the prebuilt LLVM binaries for the v1.6 release, in fact, this should save you some time and allow to skip first few steps from the guide. These binaries are generated according to the guide anyway.
Could you elaborate a bit more on what you mean by
What exactly didn't work here?
Cross-compiling is fine: you should be able to use the build script successfully both x86 and arm64 hosts.
The way you compile and link your test executable seems correct, though you should be able to simplify it:
clang++ -target aarch64-unknown-linux-musl_purecap \ -march=morello+c64 \ --sysroot /path/to/sysroot \ hello.cpp -o hello \ -lunwind -lc++abi -static
If you use prebuilt binaries, the right compiler runtime and linker will be selected, the same can be achieved by using -fuse-ld=lld and --rtlib=compiler-rt flags.
-fuse-ld=lld
--rtlib=compiler-rt
Hi Yury, thanks for coming back. Re. compiling yes that is easier, thanks, I had just copied the morello example Makefile scripts.
Re. the warnings, I had assumed these were related to the fact exception handling is not working... seems you already know about those warnings, so I guess exception handling is a bug. I investigated this issue further, so here are some more details...
Exceptions Issue
Here is a simple bit of C++ code, I cross-compile it to a linux pure-cap program using the same clang++ command line as you used above then I transfer it to the morello board and execute it.
#include <iostream> struct CMyException {}; int main() { std::cout << "Start of exception test" << std::endl; try { throw CMyException(); std::cout << "Should not print this" << std::endl; } catch(CMyException) { std::cout << "Exception!" << std::endl; } std::cout << "End of exception test" << std::endl; return 0; }
We expect on stdout to see "Start of exception test", "Exception!", "End of exception test" and in fact this happens if you build with g++. But instead we get a segmentation fault at the throw() instruction.
The reason for this is there is a dereference of a capability memory address which has an invalid tag (i.e tag==0). And looking at the generated assembler code the reason for this would appear to be because an address has been dereferenced as an integer not a intptr_t i.e the compiler has used an x-register not the c-register.
This all occurs in dl_iterate_phdr()... I had a quick look at the source code but I cannot obviously figure out what has gone wrong. Anyway, I will hand it over to you as you should be able to recreate it (or alternatively tell me if I have done something silly!)
Explaining LLVM variable in build
Ok, to explain this...
So in summary I think probably you just need to update your document to add instructions to set LLVM variable and then run the script. Also BTW there look like a few copy/paste errors in the document as it refers to building libunwind in the instructions for building libc++ and libc++abi, and finally there are no instructions in the bash_morello.sh file itself although the other targets have instructions in that file.
Hope this makes sense.
That being said, these are small points and the process was quite ok and the instructions were very helpful. The only problem I found was this need to set LLVM variable to build the libcxx case, although as I say I did not rebuild clang itself from source so I cannot comment if that step works or not.
ThanksPete
Hi Pete, thanks for the detailed report! We've made some updates on the Musl side and if you rebuild it from the top of the "morello/master" branch, you should get two improvements:
Hope this helps!
Thanks Yury, I look forward to giving it another try sometime next week!Pete
Hi Yury, just reporting back, I updated from master and re-tested and indeed the two changes you described worked well - many thanks!I appreciate there is still a little bit more work to do (e.g all those build warnings are still there), but do you have an updated estimate for when there will be an official release of this MUSL libc++ support?Best RegardsPete
