I have been trying to build the Morello software stack using the 1.3 release user-guide.rst and have not been able to get it to build.
The error I have been getting is:
Submodule path 'llvm': checked out '47853ef78a113576a9f4e927fe46409a88f1c503' Submodule path 'llvm-project': checked out '16fc6390465662de8e05f46313d61f697ede77f5' fatal: Needed a single revision Unable to find current origin/master revision in submodule path 'morello/llvm' Checking out files: 100% (19217/19217), done. Previous HEAD position was 47853ef7 Add binaries with a fix to lldb-server. Switched to branch 'morello/baremetal-release-1.3' Your branch is up-to-date with 'origin/morello/baremetal-release-1.3'. Previous HEAD position was 16fc63904656 [Morello][lldb] Remove explicit dependency of Android source Switched to branch 'morello/release-1.3' Your branch is up-to-date with 'origin/morello/release-1.3'. Fetching origin fatal: A branch named 'morello/release' already exists.Using the following command:
./build-scripts/build-all.sh -p soc -f busybox buildHave I made a mistake somewhere or is there a problem with the repository?
