Hi, I am trying to compile my .bin file for my Mbed project but I am running into this error:
Build startedUsing toolchain ARMC6 profile {'ENV': {'ARMLMD_LICENSE_FILE': '8224@10.100.182.21:8224@10.100.106.178'}, 'PATHS': {'ARMC6_PATH': '/opt/ARMCompiler6.15.13/bin/', 'ARM_PATH': '/opt/armcc5_06_u6/'}, 'common': ['-c', '--gnu', '-O3', '-Otime', '--split_sections', '--apcs=interwork'], 'cxx': ['--cpp', '--no_rtti'], 'COMPILE_C_AS_CPP': False, 'NEW_SCAN_RESOURCES': True}scan /tmp/chroots/ch-e5b93c3d-b1e7-4726-9ee0-252362a43b11/srcscan /tmp/chroots/ch-e5b93c3d-b1e7-4726-9ee0-252362a43b11/extras/mbed-os.libcompile main.cpparmclang: error: Failed to check out a license.Unable to connect to the license server. Check that ARMLMD_LICENSE_FILE is set correctly, and the license server is available.armclang: note: Information about this error is available at: ds.arm.com/.../m15 General licensing information is available at: ds.arm.com/.../ If you need further help, provide this complete error report to your supplier or license.support@arm.com. - ARMLMD_LICENSE_FILE: '8224@10.100.182.21:8224@10.100.106.178' - LM_LICENSE_FILE: '8224@10.100.182.21:8224@10.100.106.178' - ARM_PRODUCT_DEF: unset - ARM_PRODUCT_PATH: unset - ARM_TOOL_VARIANT: unset - Product location: /opt/ARMCompiler6.15.13/sw/mappings - Toolchain location: /opt/ARMCompiler6.15.13/bin - Selected tool variant: productarmclang: note: - Checkout feature: compiler5 - Feature version: 5.0202010 - Flex error code: -15Product: ARM Compiler 6.15 ProfessionalComponent: ARM Compiler 6.15Tool: armclang [5dd79400]Internal error.Build failedBuild failed
I was able to successfully compile just yesterday, not sure what has gone wrong?
You are right, the license has expired. Our IT is already working on it. I'll let you know when it's working again.
The license has been updated. Please try again now and let us know if you still have any issues.
