Hi all,
We are planning to migrate from MCUXpresso to Keil MDK. Our project is based on IMX RT1010 (or 1015) , which is an ARM M7 architecture. I am using MDK5 community license to get familiarized with IDE.
The reason for transition from MCUXpresso to keil is RTX and middleware included in MDK 6 essential edition.
I am trying to find an example of RTX project. I found some starting points in https://arm-software.github.io/CMSIS_5/RTOS/html/exampleRTX_Tutorial.html
I tried to get the below examples working in my setup (CMSIS_RTOS2_Tutorial (V2.1) & (V1.1.0))
When i copy this project to uVison, i get the following error.
I guess the example is made at a lower version than what is installed.
Below are the installed versions of Keil
IDE-Version:µVision V5.40.0.0Copyright (C) 2024 ARM Ltd and ARM Germany GmbH. All rights reserved.
License Information:Syam KrishnanCradlewiseUser-based license: Keil MDK Community (non-commercial free of charge)Valid until: Jun 1 2033. Cached until: Jul 16 2024
Tool Version Numbers:Toolchain: Keil MDK Community (non-commercial free of charge Version: 5.40.0.3Toolchain Path: C:\Users\syam\AppData\Local\Keil_v5\ARM\ARMCLANG\bin\C Compiler: ArmClang.exe V6.22Assembler: Armasm.exe V6.22Linker/Locator: ArmLink.exe V6.22Library Manager: ArmAr.exe V6.22Hex Converter: FromElf.exe V6.22CPU DLL: SARMCM3.DLL V5.40.0.3Dialog DLL: DARMSTM.DLL V1.69.1.0Target DLL: UL2CM3.DLL V1.164.11.0Dialog DLL: TCM.DLL V1.56.4.0
Can anyone help me out here ?
TIA
