I'm using Keil uVision for MDK v5.39 with Segger J-Link and trying to debug MCU from GigaDevice (part #GD32F303CB).
I'm getting "Full Chip Erase Failed" error and not able to proceed. What are the possible reason for this error?
Hello Pradeep V
I have moved your question to the Keil forum where someone may be able to help you.
Oli
Arm Community Manager
Thanks Oliver
Maybe a problem in the Flash Programming Algorithm in use. As these are supplied by GigaDevice in their GD32F30x_DFP without source, please contact them about this issue.
Thanks Andreas for the suggestion, i'll check with the supplier.
