LPC1788 HardFault on 3rd assembly instruction
In my current project I use uVision 5.38 and the compiler default V6 compiler. As a controller I have a LPC1788 that crashes to the HardFault_Handler on the 3rd (or 4th) assembly instruction.
At the start of the project I have the following instructions from startup_LPC177x_8x.s
In SystemInit I have the following instructions
However if I press F11 once I am on the "PUSH {r7, lr}" instruction the next instruction is at address 0x00000188, in other words HardFault_Handler. Where the cpu get's "stuck" on the B instruction (to the same location).
If I try the blinky demo (for the LPC1788) the SystemInit looks like this
This code does not trigger a HardFault_Handler.
Any suggestions on how to fix this?
0
