Go to Source control tab, press 'M' next to a file. Get the side-by-side presentation but the green and red highlighting of changes is not there. Used to be there. Mysteriously gone.
Thank you for reporting your observation, but
- what is the product and version in use?
I'm using Keil Studio Cloud 1.6.6. C++ source code. Target is LPC1768.
it's working ok now. Get the red & green, etc. Thanks for the help. Sorry for the delayed response.
Hello ahume,
Thank you for making the Studio team aware of this.
This is an intermittent issue, which has been reproduced with KSC v1.6.9.
To workaround this issue, when it occurs, is to close the file in the Editor view, then reload KSC and now select the file entry from the Source Control tab once again to re-open the file in the Editor and display it with highlighting in the side-by-side presentation. You may have to do this more than once.
I have added a ticket to the defect management system to fix this properly.
Regards,
Kanthan (Studio team)
Thanks for looking into that problem and providing a workaround. The red/green diff indicators are a great help!
