I am using Keil Studio Cloud for the first time. I can't create a new project. I fill everything neatly, example project , project name, make the project active... AAdd Project. and then nothing happens.... Can't select an active project.... What am I doing wrong?
I literally have the same problem, can't find any other similar problem
Same problem here. First time using this platform, and this is not exactly inspiring confidence....
Kirk
Me too ....
By today (June 2022) Keil Studio offers loading/modifying example projects.
Related:
Arm Keil | Cloud-Based Development Tools for IoT, ML and Embedded
What is new in Keil Studio: January 2022 - Tools, Software and IDEs blog - Arm Community blogs - Arm Community
The same problem for me. When I log into my new account, creating new project, as well as importing a project from file system doesn't work (no additional messages from the Keil Studio, just nothing happens). If I log into my old account, everything works as expected. My students, who created accounts a couple of months ago don't have any problems with Keil Studio, but new ones can't create projects. Any solution?
Same here - 2 accounts, older one works, new one (today) does nothing when I try to create a new project. Goes through the steps but ultimately just sits there. I have students who will be joining soon.
BTW - the marked answer is not an answer at all
Hi, sorry, I am not aware of login issues so far in Keil Studio Cloud. What type of account are you using? Is this an Arm Account or a mbed Account?
And for an aligned testing procedure, when logged in to Keil Studio Cloud, I understand, there is then currently no project in your Workspace. Please then do:File -> New … -> CMSIS Project and choose e. g. the "Example Project" "Blinky_32L4R9IDISCOVERY_RTX" from the drop-down list. Make sure the "Make this the active project" option is checked and press "Add Project" button.
After that, what exactly happens? Please describe this as detailed as possible, maybe also with a screenshot, so that one can hopefully understand, what goes on.
I too have been having this problem. Regrettably the File->New... does not work either. When one gets to new project select example, pressing select gives the message 'No options'.
Account created yesterday
I am accessing via Mbed
Using "new Mbed project" yields the expected selection window. After selecting a template, providing a project name and selecting Add Project - the selection window closes and then literally nothing happens - no errors, no messages, nothing. I have tried this multiple times over a couple of days.
If I use "new CMSIS Project", the selection window opens but there are no options in the template pull down - so I cannot proceed
Note: I have an account I made about a month ago that works fine - so this is not user error
Note: I checked my user profile, it is correct and I am logged in
What I also noticed is that some UID is displayed in User Profile for my newly created account. In my case, it is "Hello, bac37ed3-8cc2-435d-bc8a-4357071cddd3". A proper username is displayed for my old account.
Thank you for reporting this issue. We are looking into it.
Thanks,
Arek - Studio team
I confirm that we can reproduce this issue. It is reproducible only on accounts created in the last few days. We will release a fix for it shortly.
Hi Andreas58, degrengolada, KirkL, Mbed, NewUser, tj2022, Peter Green, NewUser1
Issue has been resolved. You should be able to create files/projects in your workspaces now. Thank You for reporting this issue and apologies for inconvenience.
