Counting modified bits in a 32bit data word
I have to count modified bits in a volatile 32 bit data word.
Example:
Initial counter32[32] := 0; olddata := 0x00000010; newdata := 0x0000000001;
So we have moddata := newdata xor olddata => moddata := 00000011.
So bit0 and bit1 have changed.
Now I would have counter[1]++ and counter[0]++;
How this can be done on a Cortex-M0+ fastes way?
Best regards Juergen
  •     int popcount32(uint32_t x) {
            x -= ((x >> 1) & 0x55555555);
            x = (x & 0x33333333) + ((x >> 2) & 0x33333333);
            x = (x + (x >> 4)) & 0x0F0F0F0F;
            x += (x >> 8);
            x += (x >> 16);
            return x & 0x0000003F;
        printf("%d\n", popcount32(x ^ y));
  • I think this is a workable CM0 assembler version
    pop32	PROC
    		EXPORT pop32
    		ldr 	r1, =0x55555555
    		lsrs    r2, r0, #1
    		ands 	r1, r2
    		subs	r0, r1
    		ldr		r1, =0x33333333
    		lsrs    r2, r0, #2
    		ands	r0, r1
    		ands	r2, r1
    		adds	r0, r2
    		lsrs	r1, r0, #4
    		ldr     r2, =0x0F0F0F0F
    		adds	r0, r1
    		ands	r0, r2
    		lsrs	r1, r0, #8
    		adds	r0, r1
    		lsrs	r1, r0, #16
    		adds	r0, r1
            movs	r1, #0x3f
    		ands	r0, r1
    		bx		lr
    		ENDP
  • Sorry for not (yet) understanding your solution.
    What is x? What is y?
    Have to count changed bits.
    So I have an array of 32 counters (uint32_t counter32 [32];).
    In my example bit0 and bit1 have changed, so counter32[0] and counter32[1] should be incremented.
    the result of your popcount32() is something between 0 and 63...
    Best regards
    Juergen
  • The problem here was that your task description was insufficiently clear. "Pier"'s reply counts bits the way most people would take "count the bits" to mean.  You mean something quite different.
  • So bit0 and bit1 have changed.
    Sorry for that, ok, I try again…
    I have to count bit changes in a 32bit data word, separated for each bit.
    Therefore I have 32 distinct counters in an array named counter32[32].
    counter32[0] counts bit changes of bit0, counter32[1] counts bit changes of bit1, and so on.
    Every time a bit changes, its counter should be incremented.
    olddata := 0x00000002; newdata := 0x00000001;
    olddata ^ newdata gives 0x00000011, so two bits changed.
    Here two bits have changed, bit0 and bit1, so counter32[0]++ and counter32[1]++
    Best regards
    Juergen
  • I think something like this.
    But this is tooo slow for our needs and I have no knowledge of ARM Assembler...
    MCU is a STM32G0 with Cortex-M0+.
    uint32_t counter32[32];
    olddata = 0x00000001U;
    newdata = 0x00000002U;
    void CountBits(uint32_t old, uint32_t new)
        uint32_t x;
        uint32_t mask = 0x00000001U;
        int      i;
        x = old ^ new;			// x == 0x00000003
        for (i = 0; i < 32; i++)
            if (x & mask)
                counter[i]++;
            mask <<= 1;
    void main (void)
        CountBits (olddata, newdata);
